DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge SUVs > Dodge Durango > 1st Gen Durango
Thread Tools Search this Thread
Old 07-27-2009, 08:45 PM
hydrashocker's Avatar
hydrashocker hydrashocker is offline
Moderator of Mayhem
Dodge Forum Moderator
Vehicle: Custom Built 1998 Durango 5.9L
Thumbs up Cap and Rotor Change Out
Here are the part numbers for the Preformance Ignition I put on my truck and what I'm currently running. I got a new cap and rotor from NAPA in Echlin Performance to compair them in wear as IndyDurango has talked about. I don't know what materials that the rotor is made of but it looks like the same as Accel's. The Cap is Brass contacts and posts just like Accel. The only reason I was using Accel instead of MSD is because MSD doesn't make them for the 1998 and up 5.9L and 5.2L. I also use Champion Truck Plugs gaped at .042 and replace them each year or 15k.
MSD 8.5mm Wires #32189
MSD Blaster Coil #8228
Accel Distributor Cap #120329
Accel Distributor Rotor #130328
Accel OEM Adapter to Coil #140021AH
The new Part numbers for Echlin Performance (NAPA Brass Contact Performance) that I am going to use are along with the part #'s listed above minus the cap and rotor whick I am switching out:
Echlin
Cap............MO29
Rotor..........MO26
I currently have 50,000 miles on this cap and rotor.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
Quote:
Originally Posted by rebelboy
bet your motor aint as big as your mouth is.
I don't take sides.....I hate everyone equally.
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 07-28-2009, 12:45 PM
IndyDurango's Avatar
IndyDurango IndyDurango is offline
Vehicle: 2000 Demon Durango SLT+
Keep in mind folks, NAPA has a Non-Echlin version too. Echlin is their performance line, so make sure you get the right thing.
IndyD
__________________
- Truck of the Month: 12/06 DodgeForum.com, 1/06 DurangoClub.com, 07/07 Dakota-Durango.com
- Durangoer of the Year: 2006 DurangoClub.com
Old 07-28-2009, 10:53 PM
Moderator of Mayhem
Thanks Indy......LOL
From the looks of it these performance parts look like direct replacements for Accel performance line.
__________________
Old 07-28-2009, 11:57 PM
They very well may be. I'll take the NAPA price and their easy to get availability for Accel items any day
I heard rumor that their Echlin O2 sensors for the Durango are the exact same as the Mopar part, right down to the on-part labeling. Can't confirm, but I do recommend ONLY to use the OEM O2 sensors so this may open the door to lower prices and easier availability (especially with Chryslers part sourcing problems right now due to their bankruptcy.)
IndyDurango
__________________
Old 07-30-2009, 04:49 PM
Facory Facory is offline
Hydra: How difficult was it to acces the dist. cap. I have looked back there and it looks extemely tight to work in. Any tips on manuvering the old out and the new in?
__________________
1998 Durango SLT 4X4 5.9L
HD Transfer Case, tow package, 3.92:1 LSD,TBS, K&N Filter, High Flow Exhaust, HyperTech Tuned for 87 Octane, General Grabber HTS P255/70R 16", Super Spring for Towing, Westin Push Bar (for Fords & Chevys).
Old 07-31-2009, 12:48 AM
Ya know, I was concerned about it too but after I went ahead and did my cap the first time, it wasn't as bad as I expected. IIRC, I used a stubby screwdriver.
Just make sure you know what wire goes where before you pull them off.
IndyD
__________________
Old 07-31-2009, 07:30 PM
Moderator of Mayhem
First, look at the cap and locate the 1 on the outside of the cap. This marks where number one cylinder is. The new cap goes back in the same place and is marked the number 1. You pull back the heater hose and pull the passenger side wires off marking where they go. The coil wire is in the middle. Leave the drivers side wires attached. Get a stubby Philips screwdriver on the 2 screws and lift it out. Make sure you install the wires back in the correct order as you took them off.
__________________
Old 07-31-2009, 09:12 PM
Got r done! Sure was a small space to work in. The cap was every bit as bad as Hydra's picture. I replaced the OEM with a Borg Warner cap & rotor with copper contacts. While I was at it I removed, cleaned and replaced the IAC. It was full of carbon deposits. In fact, I had to use a soft wire brush to clean up the tip. So, new cap, rotor, coil, MAP, plugs and a cleaned up IAC. Can't hardly feel it idle. Put your foot in it - oh my gawd!!. Looking forward to the next trip hauling the camper. Should be a whole lot easier going up a hill. Thankfully, the cap and rotor don't need to be changed that often. Thanks for the encouragement and pix guys.
__________________
Old 08-01-2009, 04:45 PM
Moderator of Mayhem
No problem.!
Glad you like the change! Remember that cooper doesn't last as long as brass but it will do. Replace the spark plugs with Champion Regular Copper plugs or Champion Truck plugs...... Then again I think you just did?
Also replace wires with OEM or MSD. Again I think you just did.
The last ting to do is clean the Throttle Body if you haven't done that yet.
__________________
Old 08-02-2009, 06:20 AM
Sho nuf. Next project
__________________
Tags
2000, 98, cap, change, dakota, distributor, dodge, durango, journey, magnum, performance, plug, replace, rotor, stealth, stratus, wires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
