DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge SUVs > Dodge Durango > 1st Gen Durango
Thread Tools Search this Thread
Old 07-28-2009, 05:22 PM
b_palmer b_palmer is offline
Default Air Conditioning Air Flow Problem
Hi, I've scoured the forum and have not found my problem.
I have a 2000 Durango, 5.2L, 4WD, in which the A/C works great for a while but after 30 to 90 minutes, depending on the outside air temperature and the fan setting I use, the airflow through the outlets begins to diminish until the A/C becomes ineffective. The higher the fan speed, the longer it takes to get to this point of diminished flow. Once the problem presents itself it is irreversible. I can turn the fan speed up or down and hear the fan change speed but feel very little difference in air flow through the vents. If I turn of the A/C for 10 minutes or so it will operate normally - for a while - when I turn it back on.
What's the problem?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 07-28-2009, 11:30 PM
hydrashocker's Avatar
hydrashocker hydrashocker is offline
Moderator of Mayhem
Dodge Forum Moderator
Vehicle: Custom Built 1998 Durango 5.9L
Sounds like your freezing up the core. Next time that happens try to turn on the heater to hot for a minute then back to A/C. This would melt the ice.
If you use MAX A/C then you should only run med-high and high positions. Other than that run just A/C at other speeds or if it is too strong add some heat from the dial to get the right temp and keep it from potential ice up.
__________________
Quote:
Originally Posted by rebelboy
bet your motor aint as big as your mouth is.
I don't take sides.....I hate everyone equally.
Old 07-29-2009, 12:07 AM
IndyDurango's Avatar
IndyDurango IndyDurango is offline
Vehicle: 2000 Demon Durango SLT+
On Max SC, as stated only run the AC on high or second to high.
Also, if you are freezing up, you are low on freon. If you are in a State that allows it, add a half can or so.
IndyDurango
__________________
- Truck of the Month: 12/06 DodgeForum.com, 1/06 DurangoClub.com, 07/07 Dakota-Durango.com
- Durangoer of the Year: 2006 DurangoClub.com
Old 07-29-2009, 01:40 AM
mrwilliwizard's Avatar
mrwilliwizard mrwilliwizard is offline
2001 Dodge Durango
Vehicle: 2001 dodge durango 4.7l 4x4 SLT
Send a message via AIM to mrwilliwizard
hmm mine a/c just runs poorly on low and medium settings. don't know the cause of the problem. maybe a dirty filter. not sure
__________________
2001 dodge durango 4.7l 4x4 SLT-- Afe Cold air intake, flow master 40 delta flow exhaust. future: hellwig rear sway bar, rancho shocks, 206 cams, debating on whether to get performance tune.
Old 07-29-2009, 01:43 AM
Default Max A/C
Yes, I seldom run max but when I do the fan is in one of the two highest positions. I figured that ice was forming in the core but didn't know that was a result of low freon. I'll look into that ASAP. We're in WA and experiencing record braking heat. It works well for that but when on an extended drive is when we eventually lose it. By that point, I'm no longer in max.
I have turned up the heat in an effort to try to resolve the issue and that doesn't help. I don't know what the path of the warm or cool is but would be willing to bet that the heated air would mix downstream of the evaporator.
Thank you for the suggestions.
Tags
2000, ac, air, airflow, condition, conditioner, conditioning, dodge, durango, flow, home, intrepid, problem, problems, ram, srt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
