DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge SUVs > Dodge Durango > 1st Gen Durango
Thread Tools Search this Thread
Old 08-05-2009, 02:02 AM
fahscar fahscar is offline
Question Speedie lube screwup oil 4 quarts over
2000 Durango has a 2 inch hole or slice in the valve cover. The Durango was running fine no warnings and the engine makes a missing,clicking sound then shuts off. After it cooled down I checked the oil and it showed almost an inch above level. My mechanic came and checked the oil first and confirmed my measurement of being at least 4 quarts over. The employees from Speedie lube also came and confirmed our oil measurement. Then they drained and corrected the oil level. Started the engine and it still misses badly. They found the oil was leaking out of a hole in the valve cover. Does anyone have any idea what all could be wrong. Thanks
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 08-05-2009, 07:43 AM
schusterjo's Avatar
schusterjo schusterjo is offline
Section Moderator
Dodge Forum Moderator
1999 Dodge Durango
Vehicle: 99 Durango 4X4 5.2L
Sorry but the first thing that went wrong was taking it to one of those fast oil change places.. over fill can do all kinds of damage.. Off to work will check back with ya later..
Old 08-05-2009, 09:41 AM
Duranged408 Duranged408 is offline
Vehicle: 99 Durango 7.1 mpg SLT
Hmm lets see, too much oil, high pressures in crankcase, oil frothing, air bubbles, blow by on seals, premature wear you can keep going and going on the list... Make sure everythings documented because thats an easy case against the lubers for engine replacement...
Now with the misfires.. In your case oil prob found its way past the valve seals and gummed up your sparkplugs, i'd also check your vacuum line to the air filter for blowby aswell....
If i was you i would have a dealership run over the engine to make sure everything is corrected on the Luber's cost.....
__________________
Quote:
Originally Posted by Duranged408 View Post
Kennesaw bumper ( http://www.kenmtnac.com/Dodge.html )-33" MTRs- 3"Body - T/S lift -You'll never know the rest
Old 08-05-2009, 10:56 AM
Dans01Durango's Avatar
Dans01Durango Dans01Durango is offline
Vehicle: 2001 D 4.7 SLT Stock, Third row
SUE!!! SUE!!! SUE!!! I say!!! AHAHAHAHA!!! Okay, rant over. I had gone to them once for an oil change on my in-law's car. They did all the required movements but forgot to tighten the intake hose from the filter to the tb and didn't reconnect the pvc valve hose. Car ran like sh*t on their lot and when I had them recheck everything, they found the problems. "There's your problems, no air and no vacuum!" Idiots...
__________________
Clear lenses w/ HID conversion- 6000K, strobes and LEDs, tints all around, Flowmaster 50(?)(Came with this, bought used), Prestige alarm w/ remote start, Flex-A-Lite VSC, homebrew CAI, Gen 2 wiper conversion. More to come!
Old 08-05-2009, 04:55 PM
hydrashocker's Avatar
hydrashocker hydrashocker is offline
Moderator of Mayhem
Vehicle: Custom Built 1998 Durango 5.9L
I think you kissed the motor goodbye. Time to call the company to replace the motor as per 408 and schusterjo stated.
__________________
Quote:
Originally Posted by rebelboy
bet your motor aint as big as your mouth is.
I don't take sides.....I hate everyone equally.
Old 08-05-2009, 05:02 PM
schusterjo's Avatar
Section Moderator
1999 Dodge Durango
Okay it looks like others have chimed in... I was going to say the same thing as they did. You now need to take it to a dealer and have them look it over. Going to tell you the oil change place is going to deny everything. Its going to be to to you to prove it. Your not the first nor the last to have this done at one of those fast oil change places. "If" (because i never would) I used one of those places first thing i would do "every time" would be checking the oil before i left. bottom line your looking at a total rebuild or a crate engine.
By the way welcome to the forum, sorry we don't have good news for ya though
Old 08-06-2009, 01:15 AM
IndyDurango's Avatar
IndyDurango IndyDurango is offline
Vehicle: 2000 Demon Durango SLT+
So they added oil without draining the old oil OR changing the oil filter? And then charged you for a full oil change?
OR
Did you/someone else add in WAY to much oil?
Your post just says Speedie lube reviewed the situation, not that they were the ones who did it.
You can get away with a 1/4 quart to much oil, even maybe 1/2... but never more than that. By running with a sea of oil in there, it could be everywhere and the damage that has been done is only part of the situation. You will likely continue to have issues for a long while.
If the Speedie lube caused the issue, press them for a new motor. Their insurance will pay even if the owner doesn't want to.
IndyDurango
__________________
- Truck of the Month: 12/06 DodgeForum.com, 1/06 DurangoClub.com, 07/07 Dakota-Durango.com
- Durangoer of the Year: 2006 DurangoClub.com
Old 08-06-2009, 09:12 PM
Moderator of Mayhem
Get those basterds to pay for it!
__________________
Tags
14, 2006, change, charger, dakota, damage, dodge, durango, level, oil, quart, quarts, rt, safe, screwup, screwups
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
