DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge SUVs > Dodge Durango > 1st Gen Durango
Thread Tools Search this Thread
Old 08-10-2009, 05:32 PM
hydrashocker's Avatar
hydrashocker hydrashocker is offline
Moderator of Mayhem
Dodge Forum Moderator
Vehicle: Custom Built 1998 Durango 5.9L
So did you cut weight on the car because if you didn't I'd weigh it BC I checked in on it and it says 3,200 lbs?
regardless, 3:55 gearing coupled with 2700 lbs for the car and 1600 for an open deck car hauler is 4,300 lbs. First you need to find out what VIN# you have and match it to this table. You will have to weigh in on a scale to be sure.
Quote:
Originally Posted by IndyDurango View Post
Depends on whether it has the towing package. Here is what the 2003 D is rated at:
Tow Limit (lbs.)
Durango 2WD 4.7L V-8 (f) 4650
Durango 2WD 4.7L V-8 (g) 5950
Durango 2WD 5.9L V-8 (f) 5850
Durango 2WD 5.9L V-8 (g) 7550
Durango 4WD 4.7L V-8 (f) 4400
Durango 4WD 4.7L V-8 (g) 5700
Durango 4WD 5.9L V-8 (f) 5600
Durango 4WD 5.9L V-8 (g) 7300
(f) 3.55 axle ratio
(g) 3.92 axle ratio
2003 ratings were reduced from 2002 ratings partially based on Government regs. If the above works for your needs, the 2002 will meet or exceed those figures.
HTH,
IndyDurango
Here are the Transgo kits for your ride with the 4.7L with a 45RFE transmission: You can see what they do and they are the best thing for your transmissions.
Good:
Quote:
SK®45RFE
NEW
Truck-SUV 99-04
3.7L - 4.7L - 5.7L
You will love this kit”
Prevents/Reduces: 2-3 neutral, Limp and Slip
codes. Has Tough Snap Ring, heavy duty Accumulator
Cover . Special Seals. Saves pump and VB.
Better:
Quote:
45RFE-HD2
NEW
Truck-SUV 99-04
3.7L - 4.7L - 5.7L
4 & 5 Speed
For working Trucks, HI-Performance and "Street Show Off"
Prevents/Reduces: 2-3 neutral, Limp and Slip codes.
Has Tough Snap Ring, heavy duty Accumulator Cover and
special accumulator Seals. Saves pump and valve body.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
Quote:
Originally Posted by rebelboy
bet your motor aint as big as your mouth is.
I don't take sides.....I hate everyone equally.
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 08-11-2009, 03:08 AM
Jasperstang308 Jasperstang308 is offline
Vehicle: 2001 Dodge Durango
Good:
Better:
yes sir i have taken quite a bit of weight out. drag brakes tubular kmember fiberglass hood and trunk
just click this link
http://mustangforums.com/forum/5-0l-...oject-pos.html
Old 08-12-2009, 12:04 AM
Moderator of Mayhem
Then your in luck!
Take the truck in and get the Transgo kit. If you do it when you do a transmission fluid filter then the shop is at the valve body already. It will cost like $150 for just the fluid/filter so do it at the same time for another $150. Tottal should be like $300 plus the cooler. If you have the 4.7L then;
Kit #:
45RFE-HD2
Get a transmission cooler while your there.
__________________
Old 08-12-2009, 04:12 AM
will do sir. i just had the trans serviced last year but i am sure it wont hurt to have it done again. im sure they could adjust the bands at the same time.
is part number for summitracing?
Old 08-12-2009, 12:57 PM
schusterjo's Avatar
schusterjo schusterjo is offline
Section Moderator
1999 Dodge Durango
Vehicle: 99 Durango 4X4 5.2L
4.7 has 45RE and does not have bands.... therefore no band adjustment.
Old 08-14-2009, 05:35 PM
Moderator of Mayhem
I forgot dude........LOL
Ya, no trans adjustment on the 45RE.
No, that is the number of the kit directly from Transgo site. www.transgo.com
__________________
Old 10-14-2009, 05:46 PM
carbophat carbophat is offline
sorry to semi-jack the thread, but I have a 4.7 V8 3.55 as well, wouldn't be easier to drop the back end and swap it out for a 3.92? It should be a simply swap?
__________________
2005 Dodge Ram 1500 Daytona Edition w/add K&N cold air intake for now....
2003 Dodge Durango.. stock
Old 10-14-2009, 08:39 PM
Trapstud Trapstud is offline
Vehicle: 99 Durango 4WD 5.2L 02 Suburban 4WD
unless you have a 4x4 and then you have to switch out the gears in front as well. that will go for a lot more than the shift kit.
Old 10-14-2009, 11:00 PM
Dans01Durango's Avatar
Dans01Durango Dans01Durango is offline
Vehicle: 2001 D 4.7 SLT Stock, Third row
No trans band adjustments??? Whew! At least that's a load off my mind!
__________________
Clear lenses w/ HID conversion- 6000K, strobes and LEDs, tints all around, Flowmaster 50(?)(Came with this, bought used), Prestige alarm w/ remote start, Flex-A-Lite VSC, homebrew CAI, Gen 2 wiper conversion. More to come!
Tags
02, 2000, 47l, 4wd, capaciy, dodge, durango, gen, info, pages, tow, towing, trailer, v8, wreck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
