ok this is the situation. In the mourning i get in the D . I start it up and before i go i rev the engine.then i hear a fluid running threw pipes. it only happens after i rev and it only last a couple of seconds.for only 2 or 3 times.??? any suggestions on what this can be.???oh by the way, i got the 98 5.2 durango.also it only happens when the d has been sitting for a while (hours)not days.
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad. Click here to register for free!
You are low on freon. When the compressor is cycling, you hear what fluid is in the pipe.
IndyD
__________________
- Truck of the Month: 12/06 DodgeForum.com, 1/06 DurangoClub.com, 07/07 Dakota-Durango.com
- Durangoer of the Year: 2006 DurangoClub.com
no has nothing to do with your freon, you will never hear the freon
it is air in your cooling system when you rev the water pump pushes it through your heater core and that is what you are hearing
check your coolant by removing the rad cap(when cold) I guarantee you are low
either you have a leak in the system or this sometimes points to a head gasket pushing air into the system(do you have any blow off from the overflow canister?)
but absolutely not freon you are hearing
BS.........IMHO!
Every vehicle I've ever drove you can hear the freon especially after you turn it off.
Again, you hear the "water" flowing behind the dash... it's low on freon. It cycles with the compressor on and off, on and off.
You will not hear low coolant in your Durango.
IndyD
__________________
If you read what I typed, I was referring to your post, not the fact of the subject at hand.
I'm not going to piss around with "this and that" either way.
As for the question, yes I agree with --->tbasse01<--- as this sounds like you are low on antifreeze.
Check the level and add coolant at least 50/50 or use distilled water an antifreeze. Turn the heater on hot and max fan and rear heat if equipped while installing the coolant. You might have a T-stat that has a hole in it allowing air bubbles to flow through. If not you need to take it to operating temp (about 15 minutes on idle) without the radiator cap on to fully allow the air out. Fill your coolant reservoir up and any other air should bleed out during regular driving conditions after a few cool downs and normal runs.
At least fill the radiator and fill the coolant reservoir. Make sure you test the fluid for the right protection to the abundant temperatures you operate your truck in.
__________________
Quote:
Originally Posted by rebelboy
bet your motor aint as big as your mouth is.
I don't take sides.....I hate everyone equally.
Good luck on the repairs. Let us know how it worked out for you.
IndyD
__________________
