DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge SUVs > Dodge Durango > 1st Gen Durango
Thread Tools Search this Thread
  #21
Old 09-26-2009, 01:31 AM
hydrashocker's Avatar
hydrashocker hydrashocker is offline
Moderator of Mayhem
Dodge Forum Moderator
Vehicle: Custom Built 1998 Durango 5.9L
I think you might be right. First loosen the spindle nut BEFORE you raise it. Then take out the 3 bolts that attach the bearings to the spindle on the back side (Located on the 2nd pic you provided). Next you can separate the tie rod end and turn it all the way to the right and spin the half shaft (CV joint) out of the the spindle.
As for the dog ears: These are factory installed lower ball joints. The new one will have a recessed grove on the top replacing the dog ears with a lock ring. Make sure there isn't a lock rign as well before trying to remove it. There are 2 ways of dealing with the dog ears. You can smack em straight using the tie rod separator or just push em out. There isn't that muck metal there so a straighten jobber would be the first choice I'd do then push it out. When you install the new one use anti-seize or lubricate the outside of the ball joint and control arm so to aid in installation and removal if ever needed.
If you do one then do the other side and get all the work done BEFORE the 4 wheel alignment or buy the lifetime 4 wheel alignment like I did at Firestone and get it done anytime you want.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
Quote:
Originally Posted by rebelboy
bet your motor aint as big as your mouth is.
I don't take sides.....I hate everyone equally.
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
  #22
Old 09-26-2009, 02:29 AM
wetwolf wetwolf is offline
ok, thx! I have brake pads on order too. Should be a full durango fix-it day. I just hope my power slot rotors can be turned and don't need replacing. Those were some expensive puppies. But they made a HUGE difference when braking with the trailer.
  #23
Old 09-26-2009, 02:19 PM
Moderator of Mayhem
Trailer brakes help as well.....LOL
1 full day, 1 Durango, 1 cooler of beer, and a hell of a lot of knuckle busters.......Priceless
__________________
Tags
98, 99, ball, checking, dodge, durango, grind, joint, joints, lower, out, ram, remove, signs, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
