DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge SUVs > Dodge Durango > 1st Gen Durango
Thread Tools Search this Thread
Old 09-22-2009, 01:57 AM
tonybabb tonybabb is offline
Default Gas gauge shows "Full" all the time
1998 Durango. Today we filled the tank - actually I topped it off. Then drove about 150+ miles and the gas gauge didn't move, it showed Full. When we stopped again I added about 10 gallons, or half a tank of gas. Could topping off the tank have caused a problem with the sender unit - I hope not but...
I'm thinking perhaps a broken/ loose wire might cause this behavior? I'd really appreciate some tips on how to troubleshoot this problem, so would my friend, it's his car.
Thanks again.
Tony
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 09-22-2009, 08:59 AM
Duranged408 Duranged408 is offline
Vehicle: 99 Durango 7.1 mpg SLT
I dont have any lit./time right now to run through some tests but i doubt filling with gas caused the issue Here are some snaps of the fuel pump to give ya a lil insight on the actuall level register/float
__________________
Quote:
Originally Posted by Duranged408 View Post
Kennesaw bumper ( http://www.kenmtnac.com/Dodge.html )-33" MTRs- 3"Body - T/S lift -You'll never know the rest
Old 09-22-2009, 09:35 AM
Dans01Durango's Avatar
Dans01Durango Dans01Durango is offline
Vehicle: 2001 D 4.7 SLT Stock, Third row
Wouldn't a loose wire send an "empty" signal to the gauge? I'm with Duranged, it could very well be the fuel pump's float. Time to drain the gas, drop the tank and change the pump. JMHO.
__________________
Clear lenses w/ HID conversion- 6000K, strobes and LEDs, tints all around, Flowmaster 50(?)(Came with this, bought used), Prestige alarm w/ remote start, Flex-A-Lite VSC, homebrew CAI, Gen 2 wiper conversion. More to come!
Old 09-22-2009, 11:10 PM
hydrashocker's Avatar
hydrashocker hydrashocker is offline
Moderator of Mayhem
Dodge Forum Moderator
Vehicle: Custom Built 1998 Durango 5.9L
The only way to check the harness is to drop the tank. So if your dropping the tank then just replace the pump and be done with it. Consitering the sending unit, pump, filters, and regulators are all one unit........Like Nike says....Just do it!
__________________
Quote:
Originally Posted by rebelboy
bet your motor aint as big as your mouth is.
I don't take sides.....I hate everyone equally.
Old 09-23-2009, 09:36 AM
Dropping the tank and replacing the pump can be a hassle just for a fuel gauge, esp pricey giving the fuel pump and possible strap replacement, although if it is stock it would be a good prevention on a high miles vehicle. Anyone perhaps have specs on the float voltages? you wouldnt be able to test at the pump due to the space/ locking tab unless dropping but lets make sure its not his gauge first.
Limited space @ tank
3" bdy would be the only way to get in their to test at the tank
__________________
Old 09-24-2009, 09:55 PM
Moderator of Mayhem
^ Did you cut that hole??? ^
__________________
Old 09-25-2009, 12:05 AM
schusterjo's Avatar
schusterjo schusterjo is offline
Section Moderator
1999 Dodge Durango
Vehicle: 99 Durango 4X4 5.2L
Quote:
Ya Hydra I bet he did. I had to do this myself on a transam. In order to replace the fuel pump in one of those you have to drop the axle, I said to heck with all of that and pulled out the dremel tool out, lifted the carpet and cut a 10X10 section out. replaced the pump then too JB weld to reinstall the square that I drilled out. worked fine and of man was that so much easier then dropping that axle.
Old 09-25-2009, 01:13 AM
IndyDurango's Avatar
IndyDurango IndyDurango is offline
Vehicle: 2000 Demon Durango SLT+
Yes. He cut the hole in the floor. He is going to finish it off with a nice access door so he will have easy access from now on.
IndyD
__________________
- Truck of the Month: 12/06 DodgeForum.com, 1/06 DurangoClub.com, 07/07 Dakota-Durango.com
- Durangoer of the Year: 2006 DurangoClub.com
Old 09-25-2009, 06:57 PM
Moderator of Mayhem
Awesome!
I wanted to do that as well but didn't have the balls to go through with it.
Duranged<----- Give us a direct pic of where you have to cut as best as you can. Maybe with a measuring tape or something would ya?
__________________
Tags
2004, 98, dodge, durango, fuel, fuel gauge, full, gague, gas gauge, gauge, problem, ram, ramcharger, shows, time, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
