DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge SUVs > Dodge Durango > 1st Gen Durango
Thread Tools Search this Thread
Old 10-04-2009, 04:19 PM
jugrnaut69 jugrnaut69 is offline
Thank you guys for replying. It is identical in two cars I am referencing. A 05 Sebring, and a 00 Stratus. And when I say Identical I mean it. And I have seen it described many time by many other members over the years in the past. I have done the shake test at all of the recommended locations with no pinpoint to any specific part or item. If any members of this thread can help me identify this I will definately post the procedure and outcome.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 10-04-2009, 11:00 PM
hydrashocker's Avatar
hydrashocker hydrashocker is offline
Moderator of Mayhem
Dodge Forum Moderator
Vehicle: Custom Built 1998 Durango 5.9L
I see you have tried the right sections but you need to try the Car section. Please post in one of the other car sections.
Dodge Cars or SRT Forums
But it could be the struts.
__________________
Quote:
Originally Posted by rebelboy
bet your motor aint as big as your mouth is.
I don't take sides.....I hate everyone equally.
Old 10-05-2009, 04:21 PM
Hydrashocker, thank you very much... I appreciate the help....
Old 10-05-2009, 04:33 PM
Tough Ram Tough Ram is offline
Vehicle: 1995 Dodge Ram 1500 5.9l 360 Magnum
Did you try replacing the sway bar end links. my truck has the same bad noise but in the right front only. it is a cheap fix and may or may not fix it. my noise got worse after new shocks so that is what i am gonna replace next. hope it helps
Old 10-18-2009, 09:49 PM
1armyguy 1armyguy is offline
It sounds like you may have the same problem that I had with my 06 Chevy Impala. I ended up replacing the CV shafts, tie rod ends, new tires and alignment. Still had the noise. Replaced the hub bearing and guess what, it solved the problem. I had replaced the not too far back but, the mistake I made was getting the cheap ones. Now I will only use the Timken hub assembly.
Tags
08, causing, charger, dodge, front, high, increases, left, loud, louder, make, noice, noise, speed, tire, truck, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
