Dash Air Flow Problem
Just today my Durango has started only blowing out air to the floor or the windshield (defroster). I barely feel any air come out when I switch it to blow out from the front dash vents. I can hear the blower working just fine and it blows out fine everywhere else.
When I used to turn on the defroster I could feel a little bit of air come out of the front vents but that didn't bother me. I'm guessing the problem is related. Any ideas?
Trending Topics
The doors on the Durango are run by actuator motors, not vacumn. There is a cam wheel setup that runs the dash and defrost doors off the same motor. The links in the cam usually derail so the doors won't change position. It is right above the gas pedal so you can watch it while you try to get it to move.
the controls in the dash are vacum activated at least in the 1st gen models, quite a few guys have had their dash apart to confirm that this is how the positioning is selected, and they are designed so that when you lose vacume they switch to defrost as there are times where you just NEED to have defrost and the rest of the settings are just for comfort
