Last edit by: IB Advertising
Browse all: Interior
- Dodge Ram 2nd Gen Air Conditioning and Heater Issues
Guide to diagnose trouble and recommended solutions.
Common A/C issues: problems and solutions
#241
Ac trouble
I own a 1999 Dodge Durango 5.2 v8 2wd and just charged my Ac yesterday and I put 28 ounces in it because I only have front Ac. My Ac willnt engage but I can turn it with my hands so it's not froze up. When I turn on max Ac it just blows hot air on the windshield it does that for every setting. I'm trying to find out why my clutch doesn't engage and why no matter what setting its on it only blows out hot air on the windshield.
#242
You have two separate issues. One being why the ac won't turn on and the other is a vacuum leak in the HVAC system (default no vacuum position is defrost). If memory serves 28oz is a bit over what the spec is for the front only system. Anyway you need to get a set of manifold gauges on the ac system to see what's going on and go from there.
#243
#246
03. Durango v8 magnum hot front air
Hello. I am Tired of fixing vehicles. I'm told I'm dealing with a possible front blend door issue. I had good cold air since the compressor and evap were changed last summer until all of a sudden it started blowing heat. The next day it blew cold, and in 5 minutes blew heat. What's up? What can I do to know for sure? Fuses? Relays? Hammer through dash?
#249
