Neutral safety switch
Old 10-20-2010, 08:43 PM
Dman98's Avatar
Dman98
Dman98 is offline
Default Neutral safety switch
My harness is no good and can't seem to find a replacement. Will the switch and harness from earlier models work? That harness is easy to get and they are inexpensive.from
Old 10-20-2010, 10:57 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
without your year and trans/engine info we cannot help you with this
Old 10-21-2010, 05:16 AM
Dman98's Avatar
Dman98
Dman98 is offline
Mine, 1998 Durango 5.2L 44RE
The one I want to use from earlier models
My search revealed that I'm not the only one who's had problems finding the type of harness my Durango uses.
Old 10-22-2010, 01:01 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
1998-1999 are the same.
I looked up the switch pin outs and they are the same color wires to same source pins (well at least on the 1999-2001 Ram) to the durango. There is one difference tho;
On the left side of the harness is pin out #1. This wire is supplied with a 20-VT/BK colored wire. The wire goes into the switch as "Back-Up Lamp Feed". On the 1999-2001 Ram it states L10 18BR/LG goes to "Fused Ignition Switch Output (Run)"
Now I would say its worth a try from a junk yard but I would try to find the correct harness.
Old 10-22-2010, 07:13 PM
Dman98's Avatar
Dman98
Dman98 is offline
I need the harness for my 1998 Durango 5.2L with a 44re transmission. I can't find it locally or through online search. Maybe someone has a pick n pull nearby, that has one and can get it for me. Any help would be appreciated, here's a pic for comparison.
Thanks.
Old 10-22-2010, 07:16 PM
Dman98's Avatar
Dman98
Dman98 is offline
Thanks, I'll look into it. Need to get my truck on the road before the cold weather hits.
Old 10-22-2010, 10:51 PM
shrpshtr325
THE ULTI-MOD
if i was home id take alook for ya, but did you check rockauto????they have alot of odd stuff available that other places dont
Old 10-23-2010, 08:28 AM
Dman98's Avatar
Dman98
Dman98 is offline
Yep, with no luck
Old 10-24-2010, 08:12 PM
hydrashocker
I know of a few but I think they are 2000+ but I can look.
Old 10-24-2010, 08:38 PM
Dman98's Avatar
Dman98
Dman98 is offline
Thanks
Quick Reply: Neutral safety switch
