this durango im working on is missing the relay cover which one is the fuel pump relay i just put a new fuel pump and filter in it and still no fuel pressure i put 12 volts directly to the old pump and it did not spin its got to be a relay or fuse but dont know which one it is a pic would be helpful if anybody has one
The PDC is located in the main engine bay just behind your battery and I circled the fuel pump relay for ya! For future reference however, on the under side of the PDC cover there is a diagram for which relays are which.
HTH
thanks whitewidow thats exactly what i was looking for my cover is missing i didnt know which one it was. Do you know if there is a fuse before or after the relay just asking i still need to check the relay anyway tomorrow?
That PDC cover caught my eye, just a heads up on my 1998 D the layout looks to be about the same but a few fuses and relays are in diffrent spots. I don't have an O2 or rad fan relay at all, my horn relay sits down there. Just thought I'd throw that out there.
ya so the next day i checked the fuse with a volt meter it was good so i changed the fuel pump relay with the ac relay and the fuel pump turned on so went to checker auto and bought a new one for 12 bucks. the owner said it was a 2000 durango, and the tag on the diver door said it was made in 11/1999. but i used the pic that whitewidow gave me and it seemed to be the right one for me
If your PDC cover is missing that should be something to replace pretty soon. There are a lot of relays and fuses in that area. It doesnt take much for some water to get in there and short a lot of components out possibly while driving. You should be able to get one at a salvage yard.
