Engine Code Mania
Engine Code Mania
OK, so I bought someone else's headache, and am trying to see if I can salvage a bad deal. . . .
1999 Dodge Durango
5.2L V8
Throwing multiple codes, incl:
P0720
P0300
P0301-p0308
p0123
P0308
P0204 and others randomly.
Engine clearly missing on at least one cyl most of the time.
Other random problems such as cruise control, and
gauge fluctuations. Problems with idling, and starting when
cold (probably another issue but possibly related).
Terrible fuel economy of course, and has been known to shut itself off, apparently when it was feeling moody that day.
My inclination is to send in the Computer to autocomputerexchange to be rebuilt before doing anything else.
Compression is supposedly fine, new cap, and plugs seem fine. I had the intake manifold gasket replaced. I'm just kind of hoping that the computer rebuild may solve some of the issues.
I also get the feeling that the idling issue is related to an A/F sensor issue, but the missing cylinder issue seems more important right now.
Any thoughts? Anything I should do before throwing more money away on the computer rebuild? Am I missing something obvious?
Thanks for the help!
1999 Dodge Durango
5.2L V8
P0720
P0300
P0301-p0308
p0123
P0308
P0300 Multiple Cylinder Misfire
P0301 Cylinder #1 Misfire
P0302 Cylinder #2 Misfire
P0303 Cylinder #3 Misfire
P0304 Cylinder #4 Misfire
P0305 Cylinder #5 Misfire
P0306 Cylinder #6 Misfire
P0307 Cylinder #7 Misfire
P0308 Cylinder #8 Misfire
P0720 Low Output SPEED Sens RPM, Above 15 MPH
P0123 Throttle Pos Sens Voltage Hi
P0204 Injector #4 Ctrl Circ
however, with that many codes i would lean towards needing a new PCM and then going from there, any codes which come back up can then be dealt with at a later date. I also bet if you fix these problems your fuel economy will be back where it belongs.
also dont buy a reman unit, they are known to fail quickly and then you are screwed into buying another one, whitewidow00 has a place that sells new units pre-programmed to your truck
