Power outlet not working
Old 07-25-2011, 11:40 AM
williamettedurango's Avatar
williamettedurango
williamettedurango is offline
Default Power outlet
2003 Durango Floor console poweroutlet not working. I have checked the fuse. Any other ideas. Thanks
Old 07-25-2011, 11:46 AM
williamettedurango
Default Power outlet not working
2003 Durango. My power outlet in my floor console is not working. I have checked the fuse. Any ideas Thanks
Old 07-25-2011, 12:05 PM
Old_School's Avatar
Old_School
Old_School is offline
Get a mutimeter and start checking for power to the fuse... if no power start looking for a broken wire or loose/dirty connection.
Old 07-25-2011, 12:33 PM
1969CoronetR/T's Avatar
1969CoronetR/T
1969CoronetR/T is offline
vaffanculo
Dodge Forum Moderator
Welcome to the site. I will move this thread to the first generation Durango section,
FF
Old 07-25-2011, 01:34 PM
srch4me's Avatar
srch4me
srch4me is offline
+1 old_school... sounds like a loose wire or something...
Old 07-25-2011, 03:59 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
Check the fuses in the dash.
There also could be a "hidden" set of fuses up behind the fuse panel above the E-brake. You will have to get down under the dash and look. It also could be a bad power outlet.
Old 07-25-2011, 04:02 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
the fuse for that outlet is under the hood iirc
Fuse D 20 amp in the PDC under the hood
it is the same fuse that powers the rear power outlet, the one in the dash is fused in the drivers door jam panel and is separate from the other 2
Old 07-25-2011, 08:51 PM
Brekar's Avatar
Brekar
Brekar is offline
And if it's not a fuse I'd check what you're putting into the power outlet. The reason I say this is because when I traded my 2000 Mitsubishi Eclipse I tried to use the same car charger that I used with the Eclipse but it would never work in my Durango. After checking the fuses I tried a newer one that was a different brand. Turns out the old one I was using was just a little bit to short to make contact inside the power outlet on the dash of my Durango, so now it has a permanent home inside my Silverado...
Later...
Brekar...
Old 07-26-2011, 09:33 PM
williamettedurango
Thanks for the ideas. I will check them out. Pat
Old 07-26-2011, 11:56 PM
williamettedurango
shrpshtr325 was right. Found second fuse box and problem solved.
Thanksa to all
Quick Reply: Power outlet not working
