99 durango engine swap
Old 08-18-2011, 03:22 PM
ssheffield's Avatar
ssheffield
ssheffield is offline
Smile 99 durango engine swap
I have a 99 Durango with the 5.9 in it. My motor blew and I was wondering if the 5.2 or the 4.7 with bolt right up to the tranny and everything else. I am having trouble finding another 5.9 plus I wouldn't mind going smaller with the engine.
Old 08-18-2011, 04:03 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
the 5.2 and 5.9 should bolt right up to the same transmission and motor mounts, however i believe you also need to change the PCM if you change the engine in order to get the intended performance.
the 4.7 is completely different
Old 08-18-2011, 06:10 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
+1 Sharps
The PCM will run but not at it's best. Now I don't know if you go 5.9L down to the smaller 5.2L but it's worth the try hands down.
4.7L is COMPLETELY different.
Old 08-21-2011, 10:14 PM
IndyDurango's Avatar
IndyDurango
IndyDurango is offline
It will fire and run as is. Good luck with the swap.
IndyD
Quick Reply: 99 durango engine swap
