4x4 not working
Jgap:
First off, check your fuses that go to the TCCM or transfer case control module. If they are all good, then most likely your TCCM is bad. They can be had used for $50-$150, but new they run closer to $400.
Read this post for lots of info regarding your issue.
https://dodgeforum.com/forum/1st-gen...tion-tccm.html
The switch is rarely the issue. What markings does your switch have on it?
Don
Don
