ABS, airbag lights and no spedo HELP!
Old 07-08-2012, 12:46 AM
katiedaisy's Avatar
katiedaisy
katiedaisy is offline
Default ABS, airbag lights and no spedo HELP!
My 99 5.9 durango developed these symptoms today, at the same time: abs and airbag light are on, no spedo or fan blower. Drove it across town and now it also won't turn over. No click like a bad starter, I turn the ignition and nothing. Any ideas will be appreciated.
Old 07-08-2012, 08:36 PM
topdogcustoms's Avatar
topdogcustoms
topdogcustoms is offline
it could be a bad battery or cable how old is the battery
Old 07-08-2012, 10:02 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Dodge Forum Moderator
I agree, either recharge the battery and test or replace the battery.
Old 07-08-2012, 11:10 PM
that_guy's Avatar
that_guy
that_guy is offline
try cleaning the battery terminals too.
Old 07-08-2012, 11:25 PM
katiedaisy's Avatar
katiedaisy
Thanks for the input...the cables are picky, but usually when I have trouble with them, the system shorts when I turn the key and I have to fiddle with them. Right now I have dash and radio lights and when I turn the key I lose the radio lights but keep everything else, and there is no draw on the battery and the volt reading on the dash gauge is adequate. I have cleaned the terminals w/ no difference. Would this maybe be a bad ignition switch or since the airbag and abs lights came on is there something in the system that would keep it from turning over?
Old 07-08-2012, 11:40 PM
topdogcustoms
did you have the battery load tested? a bad or weak battery will cause crazy issues
Quick Reply: ABS, airbag lights and no spedo HELP!
