Help with 2002 Durango-Starting Problems
I need some help trouble shooting what is wrong with 02 Durango. For months I had issues with no power to start-replaced battery and then starter. Had no problems until yesterday and now have no power to start. All engine lights come on but will not turn over. Put on battery charger and it jumped up to 6 amps. Had O'Reilly's check battery and its not bad just dead. Is this an alternator issue?
Sounds like you have an electrical draw somewhere. Maybe a light somewhere that is not going off: under the hood, glove box, map light. Go out on a dark night and look. Do you have an after market sound system with a sub-woofer? Could this be draining the battery?
You can take the negative battery cable off and using a multi-meter and measure the draw when the truck is off. A small amount is ok. Things like the radio draw a little bit to keep time and presets.
Might be hard to track down.
