1999 Dodge Durango Plow Setup
Old 01-26-2015, 10:36 AM
mattd860's Avatar
mattd860
mattd860 is offline
Default 1999 Dodge Durango Plow Setup
I'm looking for a used plow setup for my 1999 Durango 5.9L and I found a complete setup (Boss 7.5ft) on a 2001 Durango R/T. Is everything the same between the 2001 and 1999? I want to make sure this thing will easily bolt up to my SUV without any surprises.
BTW - if anyone knows of any other plow setups for sale that will fit my Durango please let me know (I'm located in Connecticut).
Old 01-26-2015, 12:03 PM
gvsu4msu's Avatar
gvsu4msu
gvsu4msu is offline
asphaltwarrior1 recently added a plow to his Durango.
Read this thread for discussion on plowing with a Durango --> https://dodgeforum.com/forum/1st-gen...0-durango.html
Old 01-26-2015, 06:34 PM
Old_School's Avatar
Old_School
Old_School is offline
You would be better off spending your money on a ram already with a plow... The front end isn't designed to handle a plow and you will be breaking things constantly. Might be a more up front cost way to go but, it will be cheaper in the long run with all the parts you will be breaking on the Durango.
Old 01-26-2015, 07:14 PM
moe7404's Avatar
moe7404
moe7404 is offline
number 1 get an over size radiator. 2. trans cooler. 3. mech engine temp gauge.
Old 01-26-2015, 09:52 PM
mattd860's Avatar
mattd860
mattd860 is offline
Thanks for all the suggestions. Unfortunately the Durango suffers from terrible rust rot and a slew of other problems so we have retired it. However, it still runs and drives so rather than let it sit (or give it away) I figured I would throw a plow on it just for OUR driveway. I'm not looking to run a commercial plow business. With this new information - are your suggestions still the same?
I've been plowing for years with a 4ft plow on my garden tractor. It seems to me that if that little thing can hold up like it has, that this suv should be able to handle some light plowing as well.
Old 01-27-2015, 12:58 AM
that_guy's Avatar
that_guy
that_guy is offline
In that situation I don't think you've got much to loose.
Old 01-27-2015, 09:45 AM
Old_School's Avatar
Old_School
Personally, i still would not spend money for a plow setup for a vehicle with a slew of problems but, to each there own...
Old 01-27-2015, 12:57 PM
gvsu4msu's Avatar
gvsu4msu
gvsu4msu is offline
For the money you plan to spend on a plow, why not get a snowblower?
Here is an article I read the other day about plowing with a Garden Tractor --> http://www.consumerreports.org/cro/n...snow/index.htm
Old 01-27-2015, 01:20 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
The front ends are different. The 1999 has a steering box with linkage and tie rods, the 2001 is Rack and Pinion. As for bolt up between the two, I don't know if they are compatible, but I assume they could be, of course with modifications....LOL
Old 01-31-2015, 03:49 PM
mattd860's Avatar
mattd860
mattd860 is offline
Are the frames on the 1998-1999 different than the 2000+??? I see plow undercarriages for the 2000+ plows (Boss) but nothing for the 1998-1999. I realize the steering differences but are the frames up in the front different too?
Quick Reply: 1999 Dodge Durango Plow Setup
