Just got a 2000 Durango SLT at Auction
Hey all.
I just got a really pretty 2000 Durango SLT at auction for 900. When I bought it it had the ABS light on. I got to turn it on but not put it in drive. It idled like crap at the time but the price was right. On the way home I noticed that the Ebrake wasn't fulling disengaging and then the check engine light came on. It has a bad O2 sensor on it. Also, the steering is pretty stiff. This may be normal for the vehicle I am not sure. I topped off the power steering fluid and all the other fluids as well. I will get started on the tune up a little later in the week after I do the O2 sensor. I saw a you tube video that said I may have a leaky power Steering pressure switch that may be leaking down and taking out the O2 sensor. I couldn't find it in my car. Not sure if the 2000 has this sensor. Any help on these would be appreciated. I want to get this SUV running perfectly so my wife can drive it. I love the third row seating on it.
Thanks
James
Thanks
James
Hey all.
Thanks
James
Thanks
James
Second, 2000 didnt have the PS pressure switch.
Finally,
At least I pulled that part at the junk yard. I am only out 10 bucks. ANy chance you can post a picture of the IAC and where it is? I will hit the same junk yard Saturday. Last night I did the plugs and since it will be raining tonight I will wait until tomorrow to do the O2 Sensor. I need to pull the wheels off one at a time to check the brakes as well. I went out and bought a cheep caliper set and will measure the rotors to make sure they are thick enough. I will look up the Minimum thickness of the rotors today some time. If they test good I will just replace the pads and call it good. I still need to disconnect the Ebrake cables until I can figure out why they are not fully disengaging.
Trending Topics
