need help buying bushings
I'm on rockauto trying to replace my worn out stabalizer bar bushings but i can't seem to choose the right ones, I have 4wd but some say "to frame" some say "front to control arm" some just say front inner or front outer. , if someone has time jump to rockauto for me and tell me which one to buy. I need both front and rear .
These are for the front ends at the control arm
98-99 4WD
(MOOG Part # K7359):
00-03 4WD (keep in mind 2000 was a changeover year)
(MOOG Part # K7464)
98-03 RWD
(MOOG Part # K7274)
These are for the front to mount to the frame
(MOOG Part # K7361):
These are for the rear to the axle
(MEVOTECH Part # MK7386):
These are the rear endlinks
(MEVOTECH Part # MK7371):
Make sure you measure the diameter of your sway bars with a pair of calipers (especially the rear one) because there were several different diameter bars depending on trim and other packages, especially the rear one.
The different diamter parts will have slightly different part numbers
98-99 4WD
(MOOG Part # K7464)
98-03 RWD
(MOOG Part # K7274)
