Temp Gauge Problem
Temp Gauge Problem
If this was posted previously sorry I did look just not all 600 whatever posts and I may have just over looked it for as far back I did look. I baught a 2000 dodge durango r/t 5.9 all time 4 wheel drive tow package etc. Fixed pretty much all the problems except one. Starting it cold temp gauge reads 130 and when engine heats up it doesn't move and stays on 130. After shutting it off if I turn key to power or start it the temp gauge will read correctly however if sitting it'll slowing drop back to 130 n stay there if after starting it'll drop down to 130 faster. I changed thermostat n temp sensor but didn't help any. So any one else have this problem or know solution ? Sunday I'll do tests with ohms meter etc and could take time to figure out but hoping some one here already knows possible fix or maybe give me other ideas I may not already thought of.
Thanks
Matt
Thanks
Matt
Thanx never new that one but test came up clean. Guage works fine with key just in power mode but once it's started then it'll gradually drop to lowest reading which is 130. Power from the pcm to sensor is fine, sensor even tho replaced still tested and it is fine. If I jump the wires guage still drops so I need to find a wire diagram from gauge back.
The temp sensor feeds it's signal to the PCM, then that runs the gauge. Since you've checked the gauges as OK, next I'd swap the sensor, since it's cheap and easy to do. It's a two wire sensor behind the alternator, screwing in downward (drain the coolent a bit first, left side bottom of radiator, on the side of the radiator).
