Upper Control Arm Nuts - Alignment Shop??
I put all new suspension parts under the front of my Durango (UCA, LCA, Shocks, Sway bar bushings, '03 spindles, Hub assemblies, Calipers, pads). I took it to the alignment shop and they did a lousy job, it pulled to the right and eventually developed a thunk when hitting bumps. it turns out that the nut on the upper control arm was loose. i took it back, complained, and they did another alignment but said that the nuts holding the upper control arm to the chassis need to be replaced because once they are taken off, they need to be replaced. is this BS?
I agree with the axle nuts, one time use. But, i am referring to the 2 nuts that hold the upper control arm onto the chassis. These are the nuts that must be loosened to perform an alignment. Each stud on the control arm goes through a slot on the chassis and can be moved in or out for camber/caster adjustment. I find it hard to believe that the hardware used for an alignment is one time use, if that was the case everytime the truck was aligned, i would need new nuts.
