Is rack steering repair as easy as it looks?
I have grease leak on one boot on the end of the rack. Apparently the design is where an 'inner' u-joint style rod end screws into the fixed rack, with the 'outer' end being a normal ball joint type rod end. Is this right? Is a leak onto that boot likely from the inner ball or a bad seal on the rack?
