No overdrive and no auto shifting after fishing trip
Hi all. Past weekend after a overnite fishing trip crossing couple of streams that really didn't go above the height of the tires, twice. I did both in 4hi so I wouldn't loose traction on the rocks below, which I still have. On way back I noticed I there was no auto shifting as when I offroad I don't use overdrive. I manually shift thru the gears. Back on paved road I noticed the D wasn't shifting thru the gears and hasn't been the same since. Every exterior sensor should have dried by now and I checked the sensors that would have gotten wet. Which sensor is likely to go bad after a dip in the water? What sucks more is me and my friend didn't catch any fish all night long. All i did catch was a good beer buzz! After cold start I can manually shift 1st thru 3rd until it warm up then only 1st and 3rd gears are available. I'm limiting driving to city until I get shifting and OD restored. This is rebuilt tranny installed last april so I know it's out of warranty. Any suggestions will be helpful!
Thank you for helping. first thing I checked was the t/fluid and it was still a nice red clear color, then test drove just hoping I would be low on fluid. At correct level. I spray cleaned the connector that goes to the transmission range sensor and the terminals of the sensor. Used compressed air to dry. I'm going to change the output speed sensor later today and try to get to the solenoid pack connector. I have a feeling the pack may have shorted since there are no auto shifting. Only thing is I don't know solenoid pin connections and can't find any reference that would show me illist. or schematic. it has a 46RE transmission. Again, I'm only checking anything that can be going scuba diving while getting to where I want to fish! You'd think Dodge engineers would assume SOMEONE would actually use the 4wheel options on terrains every now and then. Not like the Durango Pavement Cruisers now a days! Like your D Mine is still pretty much stock less tire changes.
It is, I had a 46re from a 1500 in my durango. Same trans, just beware they had 2 different style dust shields, a new one is only like $20 from the dealer.
