Crankshaft Position Sensor Tips
Old 09-23-2016, 01:23 AM
pjbellue's Avatar
pjbellue
pjbellue is offline
Default Crankshaft Position Sensor Tips
So I spent about 2 hours on trying to install a new CPS in the dark, before finally giving up and planning on conquering in daylight, anyone have any tips or vids or instructions? 1999 Dodge Durango 5.9.
Old 09-23-2016, 09:17 AM
TNtech's Avatar
TNtech
TNtech is offline
Site Moderator-Dodge Tech
Dodge Forum Moderator
It's on top of the bellhousing on driver's side. What's the difficulty you're having?
Old 09-23-2016, 01:49 PM
pjbellue's Avatar
pjbellue
pjbellue is offline
I know where it is, I got the old one out, is there a trick getting the new one in around the tranny dipstick without removing it?
Old 09-24-2016, 10:10 AM
pjbellue's Avatar
pjbellue
pjbellue is offline
Ok I figured it out.
Old 09-24-2016, 03:58 PM
44dakota's Avatar
44dakota
44dakota is offline
easiest way to do it, pull right front wheel off and remove inner fender, the cps will be in plain view..
Old 09-24-2016, 05:39 PM
TNtech's Avatar
TNtech
TNtech is offline
No trick, but the bore of that hole is TIGHT, especially if you are using an aftermarket sensor. You have to be at just the perfect angle for it to slide in. (that's what she said)
Quick Reply: Crankshaft Position Sensor Tips
