torsion/shackle lift
#102
#103
Aftermarket torsion keys are like throttle body spacers. 100% junk, nothing but paper weights. Iv'e ran well over 60k on a T/S with no problems. 8 turns only...
#104
#105
#107
I understood his question as what was an equivalent sized tire in 33'', not if they will fit or not, so here is your answer.
An equivalent size tire would be about a 285/75R16, 275/80R16, or 265/80R16. It really all depends on how wide you want your tires to be and how much sidewall you like.
#108
Ok....so I found this on ebay......3" Suspension lift kit 1997 - 2003 Dodge Durango 4x4
This 3" Lift kit gives your truck the typical lifted look without the drawbacks or the hassle and expense of a conventional drop bracket lift kit. The front and rear suspension travel is increased 3" making it perfect for off road or heavy construction use
The kit installs with simple hand tools, doesn't sacrifice the smooth stock ride quality and can be installed with hand tools. Our kit is made in the USA out of the finest steel, and we supply a complete kit, with instructions, Front lift keys, Rear Shackle kit, alignment specs and dedicated support.
Features:
Features:
- Maintains stock ride quality <LI style="FONT-WEIGHT: normal">2-3" adjustable front lift <LI style="FONT-WEIGHT: normal">2" Rear shackles made of 3/8" thick steel.
<LI style="FONT-WEIGHT: normal">all hardware is included, the kit comes complete <LI style="FONT-WEIGHT: normal">Allows for up to 33" tires to fit without rubbing <LI style="FONT-WEIGHT: normal">Kit can be installed in one hour <LI style="FONT-WEIGHT: normal">Alignment specs provided <LI style="FONT-WEIGHT: normal">Made in the USA - Works on all 1997-2003 Dodge Durango 4x4
#109
Thats the 3in lift they are trying to do in the front. No more than 2in with torsion bars, don't do keys. Do a body lift if you want more than 2in. The factory setup is the strongest you can get.
#110
