torsion/shackle lift
RE: torsion/shackle lift
Here are the before and after pictures, I got just about exactly what I thought I would get, just about 2 inches.
[IMG]local://upfiles/63521/A19972C577BE4D7C847DFA3DA0A5891F.jpg[/IMG]
[IMG]local://upfiles/63521/F2068B3C58D447A4A9E0E5A43DD0C33D.jpg[/IMG]
[IMG]local://upfiles/63521/72BD7203320E4F3FA7D7E3846FB81F20.jpg[/IMG]
[IMG]local://upfiles/63521/1B38DCFAAFED4E2F957147BEB8B916DF.jpg[/IMG]
Jack never moved at all, except a little bit as I started cranking once some tension applied it never moved. I put it in before I undid the shackle bolts to keep the spring loose on the bolts so maybe that's why? Then I just cranked it enough to fit the spring bolt through on the new shackle.
The T-bars come back from the front end to the frame. There is one coming back from each front wheel and looks like a pipe about 1 1/2 inch and about 3 ft long. Where they attach by the frame there is a cross member. On this cross member are 1 bolt each pointed up with a rocker style end. You will notice that the bolts are not all the way bottomed out hints the reason you take the pressure off the T-bars and crank these bolts up (close to bottoming it out). You need to crank them (turn the bolts) about 8 full turns = 2 inch in height on the front end. These torsion bars are (springs) that hold up the front end. This is done buy twisting the torsion bars with pre-load. When you crank up the torsion it raises the front end.
Then the rear end you look at the rear most part of the leaf spring and you will see the OEM shackel. It is about 2 1/2 inch in height and goes between the leaf spring and the frame mount to aid in movment when flexing. You pull these out and replace them with longer ones giving you the added height in the rear.
