'05 Ram 2500 5.7L 4x4. Truck stalled, Brake and ABS remain on
Old 01-17-2017, 12:01 PM
tigger3650's Avatar
tigger3650
tigger3650 is offline
Default '05 Ram 2500 5.7L 4x4. Truck stalled, Brake and ABS remain on
Started my truck in the driveway this morning to warm up before work. Outside air temp was 43F. Truck started normal, within 1 minute, coughed/ idled down twice and died. Walked back out to restart, had to crank a few seconds (maybe 5sec) then it started. No check engine light, but the brake and ABS lights remained lit.
Fuel light also came on, yes low on gas but still had almost 1/8th tank when parked the night before, needle is just above "E" now.
Did an oil/ filter change this weekend along with draining the transmission and replacing both filters there.
Not sure if I have multiple problems (low fuel/ wheel sensor) or if these symptoms may be all related. Had to go to work so I haven't had a chance to check for codes or mess with it, but haven't been able to pull a whole lot of info from the web.
Old 01-17-2017, 01:15 PM
TNtech's Avatar
TNtech
TNtech is offline
Site Moderator-Dodge Tech
Dodge Forum Moderator
Open the hood and unplug the ABS module. See if water has intruded into it.
Quick Reply: '05 Ram 2500 5.7L 4x4. Truck stalled, Brake and ABS remain on
