DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge SUVs > Dodge Durango > 1st Gen Durango
Thread Tools Search this Thread
Old 03-21-2006, 12:31 AM
willys_durangotang willys_durangotang is offline
Default RE: Durango Blower Switch
hey all im new here. my blower went out in my durango a couple of days ago, only high worked. read your info from here and it was the resistor. i would have never found it either, and you right, does not look the same, i even questioned the dealer! around 9 bucks and 15 minutes, everything works like a champ!!! thanks.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 06-27-2006, 09:32 PM
Mean Green's Avatar
Mean Green Mean Green is offline
Vehicle: 00' Dodge Durango
Looks like a lot of people had this problem so I will just bump it right back up.
__________________
2000 Durango 5.9L SLT+ Flowmaster 40 "Custom" Ram Air 31" BFG AT T/A KO's Bilstein Shocks Hidden Hitch Sirius Satelite Radio E-fan conversion Smittybilt brushguard SSU's
Quote:
Originally Posted by User2006 View Post
those some sexy asses... anyone got any lube?
Old 07-08-2006, 04:07 AM
blspear blspear is offline
I cannot thank you enough for this information. I have a 2002 Durango. I was on my way home from the store and the blower went out. I called the dealership and they had the part in stock. It took me about 15 minutes to install and it is working perfectly now. Thanks again for the help!
Old 10-07-2006, 03:20 PM
bozzmat bozzmat is offline
What's up people,
I'm on my second run in with this prob. First time was about 25,000 and now no heater again at 50,000. first time was done under warranty. This time I took it in the day before i went on vacation hoping they would fix it so i would have A/C. They told me the blower motor was also shorted out because of the resistor failing and they had to order one. They say the damage is about 335.00. I didn't take it back to them because i want to check the motor for myself. Does this sound right? Thanks to all in here for any info.
__________________
It takes a Mopar to catch a Mopar!
Old 10-09-2006, 02:42 AM
gtrippleb gtrippleb is offline
When I first encountered the problem I thought it was the motor that had went bad so I went to checker I think it was and picked up a motor for around $45 at the time, not sure what it is now. I replaced the motor, as it's in the same general area as the resistor, but that didn't fix my problem. Sure was mad sitting out in the ND winter with two portable heaters in the back so I could have some heat while I replaced the motor when it wasn't the motor that was bad. So I did some research and found that it was most likely the resistor and changed it out. Sure enough the resistor was the problem. If the blower motor is bad, on an 01, it's fairly easy to replace. I would think you would be able to replace it yourself without to much of a problem for less than 335.00. If the motor is bad though, then most likely it can cause the resistor to continue to go bad.
On another note, I'm glad I could help those in replacing their resistor. When I created the page, I never knew that it was, or going to be, that common of a problem.
Thanks,
Greg
www.gtrippleb.com
Old 10-18-2006, 04:05 PM
ONEENVY ONEENVY is offline
best post ever! mine just went out the other night coming home from dinner. Just my luck too, it was pouring rain! So I had to drive home with the windows cracked to keep the d from fogging up.
Old 10-19-2006, 01:10 AM
Kensai's Avatar
Kensai Kensai is offline
Vehicle: 2000 Black Durango R/T
Welp, don't forget you still have the rear blower that you can still use with the A/C settings to dehumidify your Durango even tho your front blower is out of order.
__________________
Black 2000 Durango 5.9 R/T, Infinity Reference 6012i, Clear Headlight lens,
Fastman 52mm ThrottleBody,Fastman custom built Tranny,Castrol Full Syntec,
OEM K&N Air filter,Monroe Reflexes,BFG LongTrail Touring T/A's,180 Stat,
Champion IR Truck Plugs,Hypertech III (87 oct),Custom Made Ram Air Intake,
Old 12-10-2006, 09:21 PM
cableguy1224 cableguy1224 is offline
is there two to replace if you have the one uptop in back also?
__________________
2005 Ram SLT 1500 Quad Cab 4X4
5.7 HEMI Power
Leveled Front End
17x8 Ultra Goliath Wheels
33X12.50X17 MT Tires
Magna Flow Exhaust
Debadged (Doors Only)
Billet Grille inserts
Stainless Nurf Bars
Matching Leer shell
Old 12-11-2006, 04:48 AM
Mean Green's Avatar
Never heard of a second one but it may be a possibilty.
__________________
Old 12-11-2006, 06:59 PM
hippychic hippychic is offline
Ok now I have a second question. I had posted one about my rear heat not working (would blow cold when heat was on) - now the rear is not blowing at all. Is this blower switch for the front and rear? If not how do we fix the rear heat/blower?
[sm=headbang.gif]
Tags
2002, 2003, blower, dakota, dodge, durango, fan, heater, motor, part, resister, resistor, run, speed, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
