DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge SUVs > Dodge Durango > 1st Gen Durango
Thread Tools Search this Thread
  #21
Old 12-12-2006, 03:15 AM
Mean Green's Avatar
Mean Green Mean Green is offline
Vehicle: 00' Dodge Durango
Default RE: Durango Blower Switch
Maybe it's your resistor pack which is in an announcement at the top and I'm thinking your heater lines may be plugged up or something like that for the rear heat?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
2000 Durango 5.9L SLT+ Flowmaster 40 "Custom" Ram Air 31" BFG AT T/A KO's Bilstein Shocks Hidden Hitch Sirius Satelite Radio E-fan conversion Smittybilt brushguard SSU's
Quote:
Originally Posted by User2006 View Post
those some sexy asses... anyone got any lube?
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
  #22
Old 12-12-2006, 01:26 PM
cableguy1224 cableguy1224 is offline
I called the stealership today and they told me the one in the front ALSO controls the back, SO I bought one today and will install it tonight
took me 10 mins MAX, I did one in my 2001 dakota and it was easy, just those Damn screws are hard to get access too
UPDATE
Cost was $15.00 out the door today incase anyone wanted to know
Im pretty sure that is the cheepist part you can buy at the dealer!! LOL
I installed it tonight on my 2003 durango and it was way eaiser then the 01 dakota, the screws
were in a perfect spot UNLIKE the 01 dakota
Have a good XMAS all!!!!
__________________
2005 Ram SLT 1500 Quad Cab 4X4
5.7 HEMI Power
Leveled Front End
17x8 Ultra Goliath Wheels
33X12.50X17 MT Tires
Magna Flow Exhaust
Debadged (Doors Only)
Billet Grille inserts
Stainless Nurf Bars
Matching Leer shell
  #23
Old 02-11-2007, 05:18 AM
worldpeace worldpeace is offline
Can anyone help me on this problem?
My heater only blows heat on vent (face) not by the feet or winshield, my mechanic said it would coast me around 500 $ to remove the dash and fix the problem which he wasn't sure if he could do so i tried taking off the dash myself and i don't think i know what im doing so im stuck in the middle of it and don't know where exactly isthe problem or what my next step is so i'll probably put everything back and wait till someone hopefully replies to my message because it ain't easy drivin in michigan in middle of february with heat on your face ann freezing feet and windshield
__________________
ALulanaj
  #24
Old 07-05-2007, 04:56 PM
zeus1901 zeus1901 is offline
Awesome! An $11 part and about 30 min of work fixed my problem.2001 Durango Sport, AC level 1 went out, about 3 months later level 2 went out, 2 weeks later level 3 went out and all we had was high. The link below is perfect for explaining the replacement for the Blower Motor Resistor. The only pain was unscrewing/screwing-in the back screw as its at a difficult angle.
Quote:
ORIGINAL: mgarrettjr
Try this site everything you need to know to replace the blower motor resistor with pictures.
http://www.gtrippleb.com/auto/durang...r_resistor.htm
  #25
Old 07-24-2007, 05:51 PM
MAGIC84's Avatar
MAGIC84 MAGIC84 is offline
2003 Dodge Durango
Vehicle: 03 DURANGO SLT
I just replaced mine today, had the same symptoms. My Service Adviser, gave me sort of an FYI, as to why it always goes to high when the resistor fails, basically since the variable resistance on the lower speeds are 0 it defaults to the highest setting, I guess to make sure that you at least have windshield defrost and a fan to keep ice, moisture from building up and allow you some inside heat to get home. Sounds fairly Reasonable, He also advised that if it goes out again there may be a bigger problem possibly the blower motor, but if it is going to faill it will probably go within a couple of weeks. Also for 2003, the Part Number and design changed slightly, more behind the wiring, so you wont notice anything different, the connector is the same. Local dealer Cost, Indianapolis,, IN area $15.04 (including 6% tax.) Approx10-15 minutes to remove/replace, and ops check. I am sure gladI dug into this forum andpost a little bit moreand found that.My Girlfriend hada Chevy Venturesame problem, cost her about $200 for the motor alone.
__________________
2003 DURANGO SLT 4X4 4.7 3RD ROW LEATHER SONY XM/SIRIUS STEREO MICHELIN X-RAD LT BOSCH WATER PUMP DURALAST C-MAX BRAKES DURALAST ROTORS MAGELLAN MAESTRO GPS BILSTEIN HD SHOCKS GOODYEAR GATORBACK SERPENTINE BELT. HYPRO CAI KIT. MAG-HYTEK TRANSMISSION PAN MR GASKET RADIATOR CAP WITH BUILT IN THERMOMETER.
  #26
Old 07-28-2007, 03:37 AM
IndyDurango's Avatar
IndyDurango IndyDurango is offline
Vehicle: 2000 Demon Durango SLT+
I wouldn't worry about the motor going out in connection with the resistor. Many a resistor have been replaced, but only a few motors. While it seems that they would be connected, they are not really/most of the time.
Lesson learned, service advisors at our Indianapolis stealers usually are A) wrong B) out ot take more of your money and C) if at Westgate certainly WILL take more of your money.
IndyD
__________________
- Truck of the Month: 12/06 DodgeForum.com, 1/06 DurangoClub.com, 07/07 Dakota-Durango.com
- Durangoer of the Year: 2006 DurangoClub.com
  #27
Old 08-14-2007, 12:52 AM
danab242 danab242 is offline
2001 Dodge Durango ( I love this car)
I too had the problem with the front blower stop working only the back blower was working .. I took your advise and remove the blower resistor and replaced it .. It works much better than before i was not getting to much air before. now it comes out full force... I want to thank you for the pictures where to find and remove that part.. It took me around a hour to put the screws back in not too bad for a female around 52 years old...I live in California and you know how we need are A/C..
  #28
Old 08-14-2007, 01:00 AM
Default RE: Squeaking when going over bumps
My 2001 Dodge Durango started to really sqeak when ever i go over bumps..I was told that they couldn't lube the joints because they are sealed ...Any help will be weclomed I don't trust the dealers they want a couple of hundreds of dollars just to tell me what the problem might be Any help out there?[&o]
  #29
Old 08-14-2007, 01:07 AM
Dana... congrats on the repair!!
I'm impressed [8D]
IndyD
__________________
  #30
Old 08-14-2007, 02:31 AM
Mean Green's Avatar
Dana chances are the squeak over bumps is from the sway bar. That is normally the culprit. There is a write up on how the change the bushings out in the DIY section for a Dakota, our process is exactly the same.
__________________
Tags
2002, 2003, blower, dakota, dodge, durango, fan, heater, motor, part, resister, resistor, run, speed, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
