DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge SUVs > Dodge Durango > 1st Gen Durango
Thread Tools Search this Thread
  #61
Old 01-19-2009, 12:06 AM
datbigdodge2 datbigdodge2 is offline
Vehicle: 2002 Dodge Durango 4x4 SLT
"Does high speed work for me" ... no ... it does not .. the front blower will not work at all ...but the back one works, it just quit out of no where.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
  #62
Old 01-19-2009, 12:37 AM
Mean Green's Avatar
Mean Green Mean Green is offline
Vehicle: 00' Dodge Durango
I don't think it is your resistor pack then. Go pick up a cheap multimeter and read the thread "electrical diagnosis and testing" at the top of the forum in this section. It will show you how to use the multimeter.
__________________
2000 Durango 5.9L SLT+ Flowmaster 40 "Custom" Ram Air 31" BFG AT T/A KO's Bilstein Shocks Hidden Hitch Sirius Satelite Radio E-fan conversion Smittybilt brushguard SSU's
Quote:
Originally Posted by User2006 View Post
those some sexy asses... anyone got any lube?
  #63
Old 01-19-2009, 08:27 PM
Thumbs up It worked !!!!
Quote:
Hey, I just wanted to post that I went through the process of deduction on this one and the only thing that was left to try was the resistor pack. Well, to my happiness ...It worked!!!! After driving to work this morning in 11 degree weather I had to try. Thanks so much for you all!!!!!!!! I can say that the part looked totally different but, everything worked and I picked it up at the dealer for $7.00 out the door.
Thanks again....
  #64
Old 01-20-2009, 03:36 AM
Mean Green's Avatar
Interesting...
Glad to see that it worked for you all the same. Usually when the resistor goes out you still have high speed as the current doesn't travel through the resistor.
__________________
  #65
Old 01-20-2009, 08:22 AM
Interesting...
one thing I noticed is that last week when it was so cold up here in Michigan that I never took the heat off of high. I do remember though when I turned it down lower it didn't work on the lower speeds. So maybe it went out then??? I'll keep you all informed.
Thanks so much
  #66
Old 05-20-2009, 09:57 PM
DON (Elcheapo) DON (Elcheapo) is offline
Default Durango 2001 fan switch for blower
Thanks for the help. The resistor is the issue. Two helpfull hints. (1)It is hard to access the resistor but if you pull it out first you will have less of an issue removing the connector. (2) Once disconnected and before running out to get a new one, check the connections. Use some emery paper or burnishing tool on the resistor connections and clean. Plug it back in and try the fan again prior to re-installing. saved $12.00... Elcheapo
  #67
Old 09-08-2009, 11:22 PM
durangoinwaco durangoinwaco is offline
Default keeps on a melting...
OK, i have a 03 durango SLT plus, when i got the durango, it worked fine, then the resistor and plug melted together, i searched around a bit, foud this thread, replaced the resistor and the connector, lasted about a week, then melted again. went to the stealership, luckily had a friend who worked there, and he tested the blower motor, said it was pulling to much. so i shelled out the 120 bucks for a new motor, replaced resistor and connector again and thought, great, problem solved. then it turns out that motor was defective, and pulled to much amps as well, and they were nice, replaced the blower, and gave me a new pigtail and resistor and warrantied it out. and now the problem rises again. connector melted to resistor, and now i work freakin 70 hours a week, and as you can imaginge im sitting here in the middle of texas in the middle of summer, so i said screw it, and put an inline fuse between supply and the high setting, so it blows on high, but thats it. i cannot figure it out. so i turn to you humble dodge forum folks, what could it be?????
oh and i believe the part number for the pig tail connector for the resistor is 05017124AA worked last time
  #68
Old 09-09-2009, 01:09 AM
hydrashocker's Avatar
hydrashocker hydrashocker is offline
Moderator of Mayhem
Dodge Forum Moderator
Vehicle: Custom Built 1998 Durango 5.9L
Could be a grounding problem as I've seen this before. The last one I saw was a corroded harness.
__________________
Quote:
Originally Posted by rebelboy
bet your motor aint as big as your mouth is.
I don't take sides.....I hate everyone equally.
Tags
2002, 2003, blower, dakota, dodge, durango, fan, heater, motor, part, resister, resistor, run, speed, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
