DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge SUVs > Dodge Durango > 1st Gen Durango
Thread Tools Search this Thread
Old 11-26-2006, 03:29 PM
allenbv allenbv is offline
Default How to change the rear end gasket
Hi, I need to change my gasket because the rear end has developed a slow leak. But, I have never change a rear end gasket before. I have a 2000 Durango 5.9L with limited slip. When I look at the rear end there appears to be a filler/drain cap on the lower right of center. I could not find a filler cap on the top of the rear end.
Is there a filler cap that I am not seeing?
Can someone walk me thru the steps to drain, replace and especially fill the fluid back up, I have liquid copper to make the gasket. It would be appreciated.
Thanks
Bradley
[IMG]local://upfiles/49804/828231FA76F04E6BAEB90EE7F77BEFD2.jpg[/IMG]
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 11-26-2006, 11:46 PM
Mean Green's Avatar
Mean Green Mean Green is offline
Vehicle: 00' Dodge Durango
Default RE: How to change the rear end gasket
Ok you need some red silicone first off or I heard the gold RTV is good, a razor scraper, brake cleaner, pry bay (I used my tire iron that came with the D), 2-3 quarts of mobil 1 synth 75-90 gear oil, friction modifier from the dealership, drain pan, and of course a socket set. It also looks like your plug is old so buy a new plug as well. Remove your spare tire so that you have more room under the D then remove all of the bolts on the cover and just leave the top bolt on loosely to hold the cover. Pry the cover up and let the diff drain out. Once it has drained you need to scrape all of the old RTV off of the diff and then the cover. It is also a good idea to pull any metal shavings/chunks off of the magnet (the magnet is on the bottom of the diff). once you have scraped all of the old RTV off spray the inside of the cover off with the brake cleaner and let it completely dry in the sun. Spray some brake cleaner on a rag and wipe the edges of the diff to clean all of the gear oil. Once everything is dry apply a thin bead (I think about an 1/8th of an inch is good) of RTV to the cover going on the inside of the bolt holes. Line it up and attach it to the diff without moving it around too much and smearing the RTV. Bolt the cover on in a criss-cross pattern. I like to let the D sit for 24 hours before adding my gear oil to let the RTV dry completely. Once you are ready to add your fluid put the friction modifier in and then add your gear oil through the fill hole. You want it filled about a 1/4 of an inch from the filler hole.
Have fun.
__________________
2000 Durango 5.9L SLT+ Flowmaster 40 "Custom" Ram Air 31" BFG AT's Bilsteins Sirius E-fan conversion Smittybilt brushguard SSU's Kenwood deck 2 10" Rockford subs Infinity door speakers 2 300 watt Jensen amps
Old 11-27-2006, 12:12 AM
dodgerules86's Avatar
dodgerules86 dodgerules86 is offline
Section Moderator
Dodge Forum Moderator
Vehicle: 1996 Dakota 4x4, 3.9L, extended cab, automatic.
To add to what Mean Green said, an easy way to add the new fluid is to use a fluid transfer pump or suction guns. You can see two examples here and here.
They are sold at most any auto parts store. You can still do it without one, but its been my experiance that it's a lot easier to use one.
And like Mean Green said, use a good gear oil, and since you have LSD, the additive.
__________________
If parts ain't flyin', you ain't tryin'.
If it ain't broke, fix it 'til it is!
2009 Toyota Corolla S, 1.8L, 5-speed - the daily driver.
1996 Dodge Dakota, 4x4, extended cab, 3.9L, automatic. - my baby
Old 11-27-2006, 12:30 AM
hydrashocker's Avatar
hydrashocker hydrashocker is offline
Moderator of Mayhem
Vehicle: 99' Ram 2500 V-10 Sport QC 4X4
It dosen't look like a bad gasket it looks like you just need a new filler plug. Replace the plug and clean off your dif and it should fix your problem. Your gasket looks in good condition.[8D]
__________________
I don't take sides.....I hate everyone equally.
Old 11-27-2006, 02:10 AM
Mean Green's Avatar
Yeah I was thinking that too but might as well change it. If oil can come out contaminants can come in.
Dodgerules, the front diff in our D's is a PITA to fill without a pump but you don't even need the pump for the rear. It goes in just fine.
__________________
Old 11-27-2006, 02:24 AM
Section Moderator
Quote:
ORIGINAL: Mean Green
Yea. I guess your right. It's been a while since I've worked under my truck. I know the transfer case on mine isn't too easy.
__________________
Old 11-27-2006, 04:14 AM
89Daytona 89Daytona is offline
Quote:
ORIGINAL: hydrashocker
If that rear plug is anything like the front plug on my 98 it will fall apart when you try to take it out and half will end up inside the diff, so you'll have to take the cover off and replace the gasket anyways.
Old 11-27-2006, 12:31 PM
Thanks for the information. One other question, which for me is the most important one. Where is the filler hole? Is it the same hole as the plug that is leaking?
If it is on top of the diff, how do I put the fluid in without a pump?
Thanks again
Bradley
Old 11-27-2006, 02:47 PM
steve05ram360 steve05ram360 is offline
Site Moderator
Vehicle: 2005 Ram CTD 4x4, 2000 audi TTQ
it is the same plug thats leaking... pop it out and you can put your little finger in and feel the level. it should be right at the bottom of the fill plug.
you can get a pump at the auto parts stores for about $7 bux. worth every penny.
__________________
http://www.dodgeforum.com/m_1037052/tm.htm
http://s41.photobucket.com/albums/e266/sdoherma/
Old 11-27-2006, 03:20 PM
Another way to fill it is to use a piece of hose that fits on to the oil bottle, stick the other end inside the diff and you can fill it from next to the vehicle instead of under it. But by sure to keep checking the level and have a spill pan under the diff for when you over fill.
Tags
differential, dodge, durango, end, fell, filler, plug, plugs, rear, rubber
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
Vendor Directory
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
