hey all im in the midst of installing my shackles as i type this, took a lil break, all i have to say is pb-blaster & wd-40 are the greatest things ever
haven't had to replace any of the bolts, and i bought 10 washers to be safe, so far it looks like i only need the 8 suggested, 3 on the top bolt and one on the bottom, per shackle of course (will take pics of shackles with washers)
full shackle
at leaf
at frame
also the nuts are 13/16" in size
if you are having a hard time with any of the bolts, mess with the bottle jack, when you move the leaf it will either add stress or reduce stress on the bolts either making it harder or easier to remove, 2 whacks with a hammer and i could pull them out by hand
and i hope everyone remembered to grease their shackles before putting them on
stock
after shackles
__________________
White 03 Durango SXT 4x4 4.7ltr
2" T/S lift
hey,
i did my T/S lift last weekend... what i found to be the best way to get the leaf springs down was to slide ur foot in the wheel well behind the tire and put ur foot on the top of the leaf and than get someone to hit the bolts while u jump up and down on them... worked like a charm.... and hey dont forget to torque those bolts up again in a few days... wouldnt wanna loose a shackle... That would be NO FUN
