have a 2002 intrepid, 2.7, engine swing, cam and crank sensor new, p0344
code still coming up. told by local dealer motor had to come out. possible long block w/ incorrect flywheel and or cam sensor tone ring installed. flex plate w/ wheel original. cleared codes, they return. checked plate for possible outta round, not apparent. any suggestions? got #1 at tdc, going to check if i have a signal at the cam and crank, please anybody. tired and gettin pissed. thanx.... shua, by the way, have a late 70's to early 80's ram converted over to 3/4 ton running gear, built trans and engine, dont know specifics can find out if interested, but its for sale if anybody can afford a toy in this economy.
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad. Click here to register for free!
is the cam gear correct if the cam tone ring is the wrong one it will not read correctly and will not start i installed a 2002 2.7 into a 2000 intrepid then had to change the cam and flywheel due to different tone ring signals.
