95 Intrepid no engine light, won't start
I replaced the coil pack, fuel pump and installed a used crank position sensor.
Found and replaced bad auto shutdown relay. Fuel pump fuse ok. Still do not have Engine Light at any time to show codes. Obtained very helpful manual from library, does not say what to do if light not present. I suspect powertrain control module, would like input on this.
Also replaced ignition switch. Does (and did) crank. All other lights operational. Engine light was working before this, and did come on occasionally.
There is power to fuel pump relay and to auto shutdown relay, however not to EATX shutdown relay. Previously, there was a delay of a few minutes when cold for the transmission to engage.
