Transmission shift problems - looking for ideas - DodgeForum.com
1st Gen Intrepid 1993 through 1997 Intrepids
Old 10-04-2014, 08:56 PM
spiral72
spiral72 is offline
Default Transmission shift problems - looking for ideas
Hey, I'm researching a problem that just started with my 95 Intrepid 3.3L. Maybe someone can give me insight.
314,000 miles. I change the trans fluid every ~35k miles. Original trans (never rebuilt)
I have a code 12 and code 33 blinked out on the dash, battery disconnected in the last.... and A/C relay circuit. The relay has been a problem for about three weeks. I have been too lazy to fix it.
The trans started shuddering on the 2-3 shift about 1 week ago.... doesn't slip in any gear though. Today I drove her, the transmission downshifted from 4th to 2nd under light throttle at 50mph which lurched the car forward and spooled the motor up. I bumped it into neutral immediately and rolled for 1/2 mile, back into drive to crawl the next hill.... It locked in 2nd gear "limp" mode until I was able to pull over and restart the car clearing limp mode. This happened once more on the way home. During the trip I give it 3/4 pedal up a hill, no slip. The next hill I pushed it to the floor, the transmission did NOT downshift at 55mph so I tried it one more time at 45mph but still no down shift...... no slipping either.
This leads me to believe the transmission isn't toast, but there is a control problem somewhere. I'm a very conservative driver so I have no idea how long it's been since the trans wouldn't downshift.
The fluid is red, topped off Valvoline ATF +4, smells and looks just like it should though it's due for another change soon.
I do not have any speedo problems, electrical or other problems. The engine runs perfectly. I changed a bad crank sensor about 1000 miles ago which was the first time the car has left me stranded.
Old 10-04-2014, 09:43 PM
spiral72
spiral72 is offline
I found this which contains a lot of potentially helpful information. It might be helpful to me or someone else:
http://www.allpar.com/fix/trans.html
Still looking for a way to diagnose this thing without throwing money at it.
Old 10-05-2014, 10:23 PM
spiral72
spiral72 is offline
No takers?
I disconnected the battery. Tomorrow morning will be near 40hrs. I also remember if you turn the ignition switch to start for 30 seconds it resets the computer. Maybe that's not even for this car I dunno. It seems to work on my 99 Ram though.
So it'll either make a difference which means the problem was programming, or it won't and that means it's not, or this routine did not reset the TCM or ECU. I also read about a clogged hydraulic screen or something, or a new solenoid pack... Either way I'll have to go back and read it if I decide to go that route.
I've disregarded incorrect fluid (even though I know it's not), cause it's been the same for about 30k miles, and incorrect filter which is supposed to be a possibility.... also 30k miles ago. There seems to be two speed sensors though I'm not positive...... all other systems work which would likely rule that out. I changed a bad speed sensor on my truck which kept it in 1st gear (not second gear).
We'll see
Old 10-06-2014, 07:29 PM
spiral72
spiral72 is offline
If anyone is interested:
I'm not a big fan of miracle fixes in a bottle, however after two shops told me the transmission needed an overhaul ($1300 and $1250) I added a bottle of LubeGuard. Whoopie.
I immediately noticed a difference, the transmission kinda squishes into the next gear instead of a clean shift. Ten miles later it dropped into 2nd gear "limp" at about 30mph, so it wasn't quite as exciting that time. I still don't have any error codes. No big disappointment really cause I didn't expect much from the $11 bottle of red pancake syrup.
I swear the trans is fine.... it's a control problem somehow. A plugged solenoid screen or..... something. A solenoid pack is $260 from NAPA.... a bit pricey to shotgun parts with.
Related Topics
Thread
Forum
Replies
Last Post
LONEWOLF2007
2nd Gen Durango
5
12-06-2016 05:04 PM
john_2216
3rd Gen Ram Tech
6
11-09-2015 10:42 PM
adkent
3rd Gen Durango
4
10-02-2015 11:33 PM
superadam12003
1st Gen Durango
3
08-01-2015 10:30 AM
Sparky86
2nd Gen Ram Tech
2
07-06-2015 02:12 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
