1st Gen Intrepid 1993 through 1997 Intrepids
1996 intrepid sputter
Old 06-20-2015, 09:39 AM
rusty17034's Avatar
rusty17034
rusty17034 is offline
Default 1996 intrepid sputter
i have a 1996 intrepid that will sputter like not getting gas while driving but will only do it in hot weather i have changed coil,plugs,wires,egr valve,cam and crank sensors and tps.drove all winter no problems at all but as soon as it got hot out again it started. does not stall out will pick back up and drive perfectly fine not a constant problem but happens more often when weather is hot.it is a 3.3 engine
Old 06-20-2015, 09:53 AM
jkeaton is offline
Dodge Forum Administrator
Check engine light on?
Old 06-20-2015, 09:55 AM
rusty17034's Avatar
rusty17034
no light was getting p0300 but egr valve seems to have fixed that idles fine no miss or anything
Old 06-20-2015, 09:58 AM
rusty17034's Avatar
rusty17034
does not backfire just seems like no fuel for a second could this be a map sensor problem
Old 07-03-2015, 07:44 PM
rusty17034's Avatar
rusty17034
Default problem solved
changed the map sensor now runs great no sputter on 269 mile road trip
Quick Reply: 1996 intrepid sputter
