1st Gen Intrepid 1993 through 1997 Intrepids
1997 Intrepid trouble codes
Old 07-18-2006, 09:42 PM
loganseven7's Avatar
loganseven7
loganseven7 is offline
Default 1997 Intrepid trouble codes
I am getting the Check engine light and when I put the ODB II code reader on it I am getting the following codes P0305 and P1784
I know the P0305 is MisFire on Cylinder 5, I have replaced the spark plugs and spark plug wires and the Coil pack, It did not change.
I am also getting the P1784 which reads as Transmission troubles. My Transmission fluid is still red in color and up to the correct level.
Any one have any ideas ????
Old 08-16-2006, 03:31 AM
CACKRB's Avatar
CACKRB
CACKRB is offline
Default RE: 1997 Intrepid trouble codes
Get the trans checked and check for a compresion problem
Old 08-31-2008, 07:03 PM
Ted Pitts's Avatar
Ted Pitts
Ted Pitts is offline
New Member
Question '97 Intrepid codes
I too have a '97 intrepid w/3.5 engine and have been getting that same 305 code for quite a while. When I reset the codes I can drive maybe 175 to 200 miles before I get the 305 misfire code. I have also changed Plugs and wiring but not yet corrected it yet. What about the fuel injectors, should I switch them arround to see if misfire happens on another cylinder?
Quick Reply: 1997 Intrepid trouble codes
