DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Neon > 1st Gen Neon
Thread Tools Search this Thread
Old 06-22-2007, 08:40 PM
winplet1971 winplet1971 is offline
Default RE: tb
and also do you bore out the intake manifold to match the jeep tb????
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 06-22-2007, 09:03 PM
justinsanders justinsanders is offline
Vehicle: 97 mtx built 2.4L turbo neon
Default RE: tb
idk if this is true or not but i heard going past 55mm you start to loose performance.
[hr]
Having a throttle body too big can hurt overall performance, so unless you seriously changed the air flow characteristics inside your engine, I wouldn't use anything bigger than 55mm throttle body.
[/align][blockquote][align=center]CFM Flow Numbers:[/align][align=center]49mm TB flows 252 cfm
52mm TB flows 283 cfm
55mm TB flows 317 cfm
60mm TB flows 377 cfm
[/align]At 8200 RPM a 122 cubic inch engine will need 290 cfm at 100% volumetric effiency, using the formula ((Max RPM/2)*Displacement)/1728. Rule of thumb is to go 10% over because a naturally aspirated engine can go above 100% volumetric efficiency because of cam overlap, header design, etc. Go above that and you kill low end because of reduced velocity, go below that you starve the engine for air at top end. 110% is volumetric efficiency is 319 cfm."
Based on this, 55 mm does seem to be the option for naturally aspirated (non-turbo) engines.
__________________________________________________ _____________
Similarly, going beyond 55mm is likely to have a negative effect on performance. (bottom end torque will be less, slowing ETs.)[/blockquote]
__________________
97 2dr mtx w/ 2001 2.4L enigine .020 over, no balance shafts, ross 8:1 comp. pistons, eagle rods, fully p&p head & im, 2.0 cams, big turbonetics turbo on 17psi for now, fmic, srt stg 1 injectors, spool boy mod, 4 puck racing clutch 2400lb pres. plate, no ac/ps componets. I WANA BUY AN INTAKE MANIFOLD
Old 06-22-2007, 11:27 PM
BadBrads97Neon BadBrads97Neon is offline
Send a message via AIM to BadBrads97Neon
Default RE: tb
^^^^This is true. If you havent ported your intake or dont have a good amount of mods then anything bigger than 55mm will make you lose power. And to answer your question winplet, no you dont have to bore or port your intake manifold, but it is reccomended if you decide to go with the Jeep TB because of how big it is.
__________________
B-RAD
97 DOHC MTX Swapped,Boogers,PT Clutch,Vibrant Dual Exhaust,3.0L CAI,AF/X UDP,Filled Mounts,60mm MPx TB,MSD Ignition,Custom painted Interior,SRT4 Console & Boot,KYB GR2 struts w/ Skunk2 Springs. Wanted: SRT Rims & DOHC LT Header
Old 06-23-2007, 10:57 AM
Default RE: tb
oko still have a problem with the iac motor being in the wrong spot and hitting the intake also the vacum vent that is on the stock tb is not on the jeep tb,i would think to drill and put a port for that vacum line?am i right help please
Old 06-26-2007, 02:05 AM
Default RE: tb
any help on this issue please
Tags
55mm, cfm, flows, tb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
Vendor Directory
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
