DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Neon > 1st Gen Neon
Thread Tools Search this Thread
Old 09-03-2007, 07:22 PM
99 Neon 99 Neon is offline
Default Help me =/
whats the trick to do with your neon when the service engine light comes on to figure out the code and ultimately find out whats wrong with it? its like on-off-on-off-on-off? with the radio mode?? so my check engine light hasnt been on in like 5 months honestly i washed and waxed my car and start driving down to my old hometown 45 minutes away. i was in a hurry so i was going like 90 on the highway but it was in 5th at like 4 thousand RPM's. A little while after my light came on and it has pretty much constantly blinked since which is bad. In first gear it doesnt seem to have the power. it idles at a little less than 1 RPM's and feels like its bogging and the car noticably shakes and sounds a bit diffrent. Besides it seeming to be at a power loss as well thats about it. Any ideas?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
1999 Dodge Neon Sport (DOHC)
5spd Black
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 09-03-2007, 07:27 PM
justinsanders justinsanders is offline
Vehicle: 97 mtx built 2.4L turbo neon
Default RE: Help me =/
i hadda problem like that and cylinder 4 hadda misfire so it might be running on 3 cylinders. it would idle at 1000 and run rough and you can still drive it but its slow.
__________________
97 2dr mtx w/ 2001 2.4L enigine .020 over, no balance shafts, ross 8:1 comp. pistons, eagle rods, fully p&p head & im, 2.0 cams, big turbonetics turbo on 17psi for now, fmic, srt stg 1 injectors, spool boy mod, 4 puck racing clutch 2400lb pres. plate, no ac/ps componets. I WANA BUY AN INTAKE MANIFOLD
Old 09-03-2007, 08:18 PM
figured it out i got "42 Fuel pump relay control ckt, Auto shutdown relay control ckt, No ASD relay output voltage at PCM, Fuel level sending unit volts out of range, Fuel level unit No change over miles
43 Multiple/ single cylinder misfire"
and 12 Direct battery input to PCM was disconnected within the last 50 key-on cycles
so any easy ways to fix this. i have the relay switch for the fuel p[ump which is the big fuse and im gonna put that in see if theres any changes. besdies that any input/help?
__________________
5spd Black
Tags
10, 50, auto, battery, cycles, direct, disconnected, dodge, input, keyon, location, neon, pcm, ram, relay, shut, srt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
