95 Neon loss of power SOLVED
Old 09-19-2007, 03:44 PM
punxnotdead185's Avatar
punxnotdead185
punxnotdead185 is offline
Default 95 Neon loss of power SOLVED
I got this 95 Neon that I've been having this weird problem with for a while. When I;m going down the highway and I give it like half throttle it will start to lose power compaired to quarter throttle but if I put it to the floor it will acceleate fine. Also my gas mileage sucks, I've been getting like seriously 13MPG on the highway.
Old 09-19-2007, 05:58 PM
bone33's Avatar
bone33
bone33 is offline
Default RE: 95 Neon loss of power
clogged cat.
Old 09-19-2007, 07:13 PM
mulletman11's Avatar
mulletman11
mulletman11 is offline
i have been experiencing the same prob kinda. i just noticed it in the last two days i just put in fresh oil n spark plugs. y acceleration up to 2500 is slow, then regular, my car sounds just a very tad quieter, and def gas milelage has gone down alot. not to dis anyone, but das, any suggestions??
how can i tell, any visual signs. its the stock 1994 cat, never altered.
Old 09-19-2007, 10:07 PM
Slashwannabe's Avatar
Slashwannabe
Slashwannabe is offline
yeah 2500 Rpm on mine is when it grows ***** as well, when I replaced my Timing belt and put it all back together it had major ***** for 3 days, now it kinda has gotten slower off the line its not the worst right now but I'm not exactly asconfident in aoff the line raceas I was when it was running so good last week.
So right now I'm wondering what causes the change in off the line power as the 2500Rpm+ range is always consistant no matter the weather.
Old 09-19-2007, 11:19 PM
mulletman11
ddint answer my question......DAS???
Old 09-20-2007, 05:55 AM
Slashwannabe
I'm having your problem as well with slow accelleration up to 2500 Rpm... its not asslow as it used to be after my water pump and belt change but its not exactly a Rocket either off the line.
Old 09-20-2007, 10:41 PM
mulletman11
anyone have an answer??
Old 09-20-2007, 11:12 PM
12 volt's Avatar
12 volt
12 volt is offline
im thinkingcold O2 sensor
Old 09-21-2007, 09:07 AM
tattoojack's Avatar
tattoojack
tattoojack is offline
i would have to lean towards the clogged cat. especially if its still the stock 94. other wise look into your fuel filter. the recommend changing every 8-12k miles and who the hell actually does that? most of the time any power loss on my end has been the result of some kind of clogged something.
Old 09-21-2007, 01:02 PM
das2123's Avatar
das2123
das2123 is offline
I'd imagine that you have a bad 02 sensor and it's not reporting correctly in closed loop and dumping fuel.
Quick Reply: 95 Neon loss of power SOLVED
