DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Neon > 1st Gen Neon
Thread Tools Search this Thread
Old 08-12-2008, 11:21 AM
Sturly Sturly is offline
Junior Member
Vehicle: My name is Steve, I love cars, movies, music, and hanging out.
I have always heard that mod for mod it doesnt make that much difference at the track if you are using the dohc or the sohc if you build each one right! I would rather comb the junkyard for spare turbo bits than a dohc motor and fool around with all that myself!
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 08-13-2008, 03:54 AM
fsu182 fsu182 is offline
Send a message via AIM to fsu182
which is pointed out in the sticky. lol. 2.4 swaps ftw
although i think that could change ur class in certain events. in our auto-x they dont let you shift higher than third. so at 7500 rpm in my 3.94 my car is at about 96mph. so im glad im running a DOHC.
__________________
99 Sport MTX 2dr
too many mods...
DOHC - life above 6750
Join the DOHC side - http://dodgeforum.com/forum/groups/
Old 08-14-2008, 12:49 AM
I_Ride_Neon's Avatar
I_Ride_Neon I_Ride_Neon is offline
1996 Dodge Neon
Vehicle: 99 r/t DD
Cool. But I still need to know what gives the California car the lower compression. Then I can mix and match to get a even lower compression ratio thats ideal for boost.
Old 02-03-2009, 01:57 AM
cleaned up since the forums changed. srry zach i haven not been able to find that info for you. would be nice to know since im trying to turbo too
__________________
99 Sport MTX 2dr
too many mods...
Join the DOHC side - http://dodgeforum.com/forum/group.php
Old 04-13-2009, 11:05 PM
IceMan(Mopar_Freak) IceMan(Mopar_Freak) is offline
Exclamation clarification
in the bottem paragraph are you saying that if i get the camshafts out of a dohc 2.4 liter chrysler they have more torque versus a stock dohc 2.0 liter?
4. Is the 420a engine from an eclipse the same as the neon DOHC?
No, the Neon 2.0 DOHC (Engine code: ECC) and Avenger/Sebring/Eclipse/Talon2.0 DOHC (Engine code: 420a) are different. Similar, but different. In other words your neon does not have a 420a engine. This is a common misconception among new 1st gen DOHC owners. The 420a head is unique and has reversed flow; The exhaust manifold sits in front of the car and wraps down in front of, then under the engineblock.The air intake is routed behind the engine towards the rear of the compartment to enter the head. Many bottom end parts for a 420a will work for the ECC such as pistons, rods, timing components, bearings, head gasket, etc. Another common swap is for neon owners to use the valve cover from the 420a (which is has raised lettering that reads: "DOHC 2.0L 16 VALVE."
Also note that the neon DOHC (ECC) shares onlyits cylinder head in common with one other engine: the Chrysler 2.4 DOHC engine found in the 1st gen stratus, caravan, etc. They are the exact same casting number. If you look at the back of the cam gears on the ECC's head, they read "2.4 front." This is because the gears are flippedwhen used on the 2.4 DOHC. The camshafts, however, are different. The bottom endon the 2.4 is also different. It has a longer stroke and produces more torque. It is also popular to swap the 2.4 DOHC into 1st gen neons. In most cases you will find a 2.4 swap to be more worthwhile, but requiring more work and parts.
Old 04-14-2009, 12:11 AM
Default floating
would it be more likely to float a valve in the swap from a single to a dual over head cam because of the pistons being flat top
Old 04-14-2009, 11:19 PM
sabin420's Avatar
sabin420 sabin420 is offline
1995 Dodge Neon
Vehicle: 95 NEON, 03 RAM 5.7 HEMI
No. to "Float" a valve is when the valve springs can't return the Valve to it's closed position fast enough. This most commonly happens at high RPM's with fatigued valve springs.
__________________
03 Ram 5.7 HEMI cold air intake, Cat Back Dual exhaust
95 Neon with all the fixins minus the Turbo
12.5:1 Compression N/A Tuned
Old 04-22-2009, 03:09 PM
willches1 willches1 is offline
if your swapping a blown 2.0 for a newer one, can you just unbolt the transmission and jack the engine up? or do you have to take the tranny out too?
Old 04-22-2009, 03:18 PM
Altima_wb Altima_wb is offline
Vehicle: 97 DOHC 5spd neon sport
Send a message via AIM to Altima_wb Send a message via Yahoo to Altima_wb
i think it might actually be easier to take the whole assembly out... not sure if there is enough room....
__________________
91 Chevy K1500 (current stock 305 to mildly built 350 swap in the works)
97 Olds minivan (wifes ride lol)
New Project 97 DOHC neon sport (Project daily driver :P)
Old 04-23-2009, 12:20 AM
sabin420's Avatar
1995 Dodge Neon
If you don't mind doing the axels, taking it out w/ the tranny is easier. Otherwise, for an Automatic, you can just pull unbolt it from the tranny and pull it straight out.
__________________
Tags
02, 20, 97, alternator, bosch, cover, dodge, dohc, durango, fit, harness, magnum, motor, neon, sohc, turbos, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
