DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Neon > 1st Gen Neon
Thread Tools Search this Thread
Old 04-15-2008, 12:54 PM
boxerjl2 boxerjl2 is offline
Default RE: Changing the Oil to much
Quote:
If you are going to use Mobil 1, then I would not change it every 1500-2000 miles. That would be just like pouring money down the drain. The 3month/3000 mile oil change is completely outdated. The commercials still advertise this because they want to sell you more OIL!!! The truth is, conventional oil can be changed every 5000 miles and true synthetic oils can be changed every 8000-10000 miles.
ok but it cost money to have a car i understand that you dont have to change your oil.. but for 30 or so bucks why not prolong the life of you engine???
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
98 MTX Highline, 2.4 Swap With :Mopar PCM, 2.5' Exhaust, Granatelli Plug Wires, F1 Clutch, 3.0 CAI, Atx Tb, 2.0 Cams, UDP, 24# Mustang injectors, Chikara Header,Solid Motor Mount Inserts ,Booger Bushings, PS/AC/Balance Shaft Removed,
2240 lbs
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 04-15-2008, 01:09 PM
das2123's Avatar
das2123 das2123 is offline
Section Moderator
Dodge Forum Moderator
Vehicle: 96 ACR
Because you will be draining out perfectly good oil. Are you gonna start changing your plugs every 1000 miles or so as well?
Running Mobil 1 oil and draining at the appropriate times WILL prolong the life of your engine.
__________________
My For Sale Post
96 ACR
12 volt's Avatar
12 volt 12 volt is offline
Vehicle: 98 neon sport
because the oil isnt dirty yet. You can do it if you want, but its not going to hurt anything if you go to 5000.
i would be kinda mad if i was droping my oil and it was still clean.
__________________
98 neon Sport SOHC/mtx, DOHC pistons, 95cam, audio system, toggle switch ignition, K&N insert
95 neon (parts car)
Old 04-15-2008, 01:18 PM
sparky3009 sparky3009 is offline
My 98 has almost 230,000 on it and it's had mobile 1 full synthetic or amsoil since the day it was driven off the lot. Changes have been every 5,000 and it's still pulling strong. She's ready for another 230,000
__________________
98 neon sport
100% stock
229,xxx miles
original clutch, head gasket, and timing belt (putting in new belt soon)
Old 04-15-2008, 01:21 PM
das2123's Avatar
Section Moderator
Vehicle: 96 ACR
^^^Have you ever has the head off? Just wondering how purrty she would look.
__________________
My For Sale Post
96 ACR
Old 04-15-2008, 01:23 PM
Not recently. The oil has never come out real dirty, but I can imagine after that many miles there would be some crap built up in there.
__________________
98 neon sport
100% stock
229,xxx miles
Old 04-15-2008, 02:02 PM
well b4 i change the oil ill check the color ..
but i dont see how waiting till your oil is diry could prolong the life or your engine.. i would think if you kept fresh clean oil in there it would last longer but your saying that leaving the oil in there till its black and dirty will help my engine last longer
__________________
2240 lbs
Old 04-15-2008, 02:06 PM
das2123's Avatar
Section Moderator
Vehicle: 96 ACR
Black oil doesn't mean its bad...it means its doing its job and cleaning the internal engine parts. I am not saying to leave it until you don't think it will help you. But after about 8000-10000 miles it would be time to change it based on the detergents and additive packages that are in the oil. Not the COLOR!
__________________
My For Sale Post
96 ACR
Old 04-15-2008, 02:07 PM
chenzo's Avatar
chenzo chenzo is offline
Vehicle: 1998 Dodge Neon R/T
i dont think they are saying wait till its black and dirty, just wait a bit longer especially if your using mobile 1.
__________________
1998 Dodge Neon R/T-3.0 CAI, Ractive Mid-length header, 3A Muffler, Filled FMM, Prothane Side Mount inserts, Smoked Tails
Old 04-15-2008, 04:40 PM
ok
ill see what i can see
and ill still change it from 3-5k
__________________
2240 lbs
Tags
ati, intervals, longer, oil, procharger
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
Vendor Directory
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
