DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Neon > 1st Gen Neon
Thread Tools Search this Thread
Old 08-31-2008, 11:03 AM
12 volt's Avatar
12 volt 12 volt is offline
Vehicle: 98 neon sport
yeah, lash adjuster is the same thing as a lifter. i would never expect the rocker arms since they have minimal moving parts, if anything along that i woulh say rocker shaftes or loose roller.
did you remove any sensors when you changed the arms?
how do you know you have spark and fuel?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
98 neon Sport SOHC/mtx, DOHC pistons, 95cam, audio system, toggle switch ignition, K&N insert
95 neon (parts car)
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 08-31-2008, 11:53 AM
schrack schrack is offline
I knew i had spark by pulling wires of when cranking & plugs were getting wet. The problem was the battery is going bad. The rocker arms definately helped, not as loud of ticking as before. There is still some ticking at low speed driving, & idle, seems like after the car shifts into into high gear the noise dissapears. It is definately on the top end of the motor, just cant figure it out. Have replaced 16 new lash adjusters, & 16 new rockers. I dont think it could be the cam or valves, like the mechanic at the mopar garage said it would not run right if it was either of those. Any ideas?
Old 08-31-2008, 01:02 PM
chenzo's Avatar
chenzo chenzo is offline
Vehicle: 1998 Dodge Neon R/T
my tick is definately not normal valve tick. its louder than ive ever heard before. ever. im having my buddy come out and look at it today, so ill keep you posted on what it was.
__________________
1998 Dodge Neon R/T-3.0 CAI, Ractive Mid-length header, 3A Muffler, Filled FMM, Prothane Side Mount inserts, Smoked Tails
Old 12-05-2008, 10:02 PM
rancidzero13 rancidzero13 is offline
Vehicle: 98 dodge neon dohc
i had the same problem...just a small tick at first...then a loud knock...havent checked the rods...but pulled the cam covers off and found one rocker arm completely off the lifter...and the cam wasnt worn at all...neither was the rocker arm...just thought this might help
__________________
98 neon DOHC stock....for now
Tags
adjuster, arm, badcom, cam, car, dodge, fine, head, lash, motor, offcom, popping, ram, rocker, runs, ticking, tickingbut, valve, wwwdodge
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
