in light of recent events, im making this post.....so,
to do this, you will need the following parts:
rear disk brake rotors
rear brake pads
rear brake lines (just the rubber hose thats located in the wheel well)
rear calipers
rear rotor backing plate w/e-brake setup
e-brake cables
now, to take the rear disc brake setup off a car:
1: jack up the rear of the car.
2: remove the rear wheels.
3: remove the 2-10mm slider bolts that hold the calipers to the backing bracket.
4: then disconnect the rubber brake line from the steel rake line located in the front side of the inner fender well. then unbolt the rubber brake line mounting bracket from the inner fender well.(2-10mm bolts)
5: unbolt thelast rubber brake line mounting bracket from the inside of the rear strut.(1-10mm bolt)then set the brake line and caliper aside.
6: slide the rotor off the lug nut studs, make sure the e-brake isnt engaged or it wont come off very easy.
7: use a screwdriver to pry the dust cap off the hub bolt.
8: remove the hub bolt and slide off the rear wheel bearing. (1 1/8" socket works i do believe)
9: behind the wheel bearing you will see 4-15mm bolts in a square pattern. remove all 4 bolts and the backing plate/caliper mount will come loose. before you can remove the backing plate, you will need to remove the e-brake cable from inside the car.
10: follow the e-brake cable underneath the car along the jack rail, you will find a bracket that mounts that cable to the bottom of the car, remove the 1-15mm bolt holding the bracket to the car and the cable should hang freely
11: to remove the e-brake cable from inside the car, remove the center console, to do this, there are 4 screws inside the center console arm rest/cubby, and 2 screws around the edge of the cup holders in front (if its a 97-99) or, in the cup holders (if its a 95-96)
12: once the center console is out, make sure the e-brake handle is all the way down, then remove the 2-13mm bolts that mount the handle/bracket to the car.
13: once the handle is un-mounted, it will be easy to turn it to dislodge the e-brake cable square ends. then use a 9/16"box end wrench and slide over the cable end. push the wrench all the way to the end of the cable and over the cable retaining clips. once the wrench is in the proper position, you will be able to pull the cable out from the rear through the mounting brace.
14: once the cables are loose, you can pull them out through the underneath of the car.
then there you go. you have everything needed to do a rear disc brake swap. the steps will be the same for removing the drum brakes from your car. and installation is the opposite of removal.
i wrote this all from memory, so if im missing sumthing, feel free to let me know and i will add it.
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
excellent post!! but where do you buy the parts and wat model car and wwhere do you go or what web site do you get everything i need ?? and maybe a more powerfull master cylinder??
__________________
96 neon engine decesed. building turbo. hr 259 cam,springs,port&polish,venolia custompistons,long rods, moroso pan, boss 3200 stall , red eagle trans kit,1 or 2 t 25 turbos, rc engiering 42 pound injectors(got free)custom coolers for trans,engine,air
i personally swap to disc brakes just because i like the looks of them better and for the ease of replacing them when they go bad compared to drum brakes
i dont think its much because of the fact that its on the rears, never looked into it tho, im more worried about fade since ill be running really wide hoosiers
i think the reason they would stop better is due to having more surface area in contact then disk pads due
__________________
1996 SOHC 2 DOOR BASE
PACESETTER HEADER/GLASSPACK
UNORTHODOX RACING ALTERNATOR ONLY PULLEY
FIDANZA ALUMINUM FLYWHEEL AND 4 PUCK KEVLAR CLUTCH
MOPAR STIFF MOTOR MOUNTS AND PROTHANE RACE INSERTS
VITORS POLY BUSHING BOBBLE STRUT
QUAIFE LSD
