DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Neon > 1st Gen Neon
Thread Tools Search this Thread
Old 03-24-2009, 04:35 PM
ldiablo233 ldiablo233 is offline
I'm going to take it to my friends shop in a day or two to do the compression check and look at everything. I was at min today on oil, so I went to the store put a quart in. As soon as I put it in I drove away and already saw smoke, which would suggest the new oil was still going down from the head to the block and leak into the cylinders. When I was driving this morning on the min level of oil even under a bit of WOT there didn't seem to be any smoke so I'm gonna guess for HG. Only thing I'm wondering is, is it possible for a warped head to leak only oil or only coolant in cause thats what confused me is the fact that they both drop down at the HG????
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 03-24-2009, 04:49 PM
Bigrmopar Bigrmopar is offline
Vehicle: 78 dodge magnum xe 96 neon 89 dakota
you said the ring are on correct, does that mean u just rebuilt engine? fresh engine will burn a little oil until the rings are broke in.
Could also be valve stem seals mines all torn down right now and from what i see leaked the most oil into the cylinders.
__________________
1978 Dodge Magnum XE T-tops 360
96 Neon
Old 03-24-2009, 11:26 PM
sabin420's Avatar
sabin420 sabin420 is offline
1995 Dodge Neon
Vehicle: 95 NEON, 03 RAM 5.7 HEMI
sorry, got them backwards...been a long time since i've dealt w/ a car smoking...not since I drove a FORD...engine blew after a month...only cost me $100...got my money's worth...left it on the side of the road and walked away...got my dodge...bought many other dodge's...all still run great.
__________________
03 Ram 5.7 HEMI cold air intake, Cat Back Dual exhaust
95 Neon with all the fixins minus the Turbo
12.5:1 Compression N/A Tuned
Old 03-24-2009, 11:33 PM
sabin420's Avatar
1995 Dodge Neon
Quote:
Originally Posted by DOHCgarrett t3 View Post
That, and I can't remember which member is rebuilding their engine or engines this week to the next anymore.
Garrett, I always got an engine I'm building...road racing breaks a lot of parts quickly, harsh on motors and trannys.
ldiablo233, It is a possibility for the head gasket to leak like that, but I would check the valve stems and the oil rings (3rd set of rings - 3 part ring) I had a head gasket leak from one cylinder into the coolant...but it was a pinhole leak, car never smoked, but it caused my coolant to constantly leak out of the overflow cause the excess pressure.
__________________
Old 03-25-2009, 12:34 AM
I only rebuilt the block not the head so it is possible that its those. Can I inspect the seals if I pull the VC and if its those then where would I get some new seals??
Old 03-25-2009, 01:18 AM
its really hard to get a close look at seals through the springs. Were the intake runners black when u had the head off?
__________________
96 Neon
Old 03-25-2009, 10:20 PM
9neon5 9neon5 is offline
Yea oil. The compression test should help you troubleshoot whats wrong. If theres low compression between two cyliniders it has a possibility that maby the head gasket cracked and is not sealing it would explain low compression if thats the case. Good luck hope it not too serious.
Old 10-22-2009, 12:50 AM
HelpaGirlOut HelpaGirlOut is offline
If I read right, My car is doing similiar.
Whiteish smoke coming out of the tailpipe and I keep having to feed it oil. it has burned about 2 quarts in a little less than a month.
feels as if it has loss of power.
smoke kinda smells like oil
no oil leaks on the ground.
what could it be?
Old 10-22-2009, 09:42 AM
das2123's Avatar
das2123 das2123 is offline
Section Moderator
Dodge Forum Moderator
Vehicle: 96 ACR
HelpaGirlOut,
Valve seals or head gasket leak in the engine would produce the white smoke. Take a look at your coolant to see if it's muddy looking.
__________________
My For Sale Post
96 ACR
Old 10-22-2009, 11:28 AM
adrenalinejunki adrenalinejunki is offline
i got a 97 SOHC that when i pulled the plugs, i found oil all over the end of the plug wire and the plug was soaked? wat is it? Valve gasket?
Tags
57, 95, coolant, dodge, found, hemi, intake, mixing, neon, oil, ram, smoke, sprinter, start, sucked
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
