DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Neon > 1st Gen Neon
Thread Tools Search this Thread
Old 03-21-2009, 04:38 PM
ldiablo233 ldiablo233 is offline
Default Oil or coolant
I was out basically all my oil after like 100 miles of driving and yet the smoke is really white which is said to be coolant. Car doesn't overheat, at times it reaches just above the halfway but could be cause my looped line is kinda kinked and only have 1 fan. No oil on the ground anywhere. Is there anyway to tell which it is? If it take it to a shop will they diagnose the problem for free?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 03-22-2009, 12:00 AM
12 volt's Avatar
12 volt 12 volt is offline
Vehicle: 98 neon sport
there is no reason you should be burning coolant, the smoke that your seeing is most likly an internal oil leak.
__________________
98 neon Sport SOHC/mtx, DOHC pistons, 95cam, audio system, toggle switch ignition, K&N insert
95 neon (parts car)
Old 03-22-2009, 12:37 AM
das2123's Avatar
das2123 das2123 is offline
Section Moderator
Dodge Forum Moderator
Vehicle: 96 ACR
Leaky piston rings?
__________________
My For Sale Post
96 ACR
Old 03-22-2009, 11:18 AM
The rings are all on correct but seems to smoke in all 4 cylinders when I remove the SP's. The engine was honed. Would the head resurfacing solve the problem since the oil goes from the head to the block at the HG?
Old 03-23-2009, 12:03 AM
sabin420's Avatar
sabin420 sabin420 is offline
1995 Dodge Neon
Vehicle: 95 NEON, 03 RAM 5.7 HEMI
white smoke - oil
black smoke - rich fuel mix
light blue/green smoke - coolant
__________________
03 Ram 5.7 HEMI cold air intake, Cat Back Dual exhaust
95 Neon with all the fixins minus the Turbo
12.5:1 Compression N/A Tuned
Old 03-23-2009, 03:30 AM
Then def oil. My friends trying to get some guys to check it out but what needs to be fixed/is the issue if theres oil getting in there?
Old 03-23-2009, 07:21 PM
12 volt's Avatar
do a differential compression check, this should help find where your leaking
__________________
95 neon (parts car)
Old 03-24-2009, 12:02 PM
GLXRustang GLXRustang is offline
Vehicle: 1998 Dodge Neon Sport Coupe DOHC ATX
sorry, but I must interject..
-White smoke is white because it's steam, not smoke thats coolant getting into combustion chamber, usually head gasket
-Blue smoke is burning oil, from a stop or first start, its valve seals, when on the gas it's rings or PCV.
-Black smoke is overly rich mixture, I agree with that
Never heard of green smoke though, better change the flux capacitor
__________________
My Toys...
Neon DOHC Coupe = ATX Shift Kit, CAI
Mustang = 4.10's, Trans-brake, and GT45 Turbo
http://www.cardomain.com/ride/2456828/1
Old 03-24-2009, 12:33 PM
das2123's Avatar
Section Moderator
Vehicle: 96 ACR
Quote:
That only activates at 88 MPH
__________________
My For Sale Post
96 ACR
Old 03-24-2009, 03:03 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3 DOHCgarrett t3 is offline
Vehicle: 98 RT Neon Sedan
Send a message via Yahoo to DOHCgarrett t3
Speaking of which, does anyone have a flux capacitor for sale? Mine went out when I got here.
anyways back on topic. I agree with GLX and the smoke colours.
First thing I would do is Drive for a bit and Keep a good eye on all the fluids. Listen for bubbling coolant and keep an eye on the smoke and see if it subsides. I noticed after I redid the head. I had quite a bit of oil in the combustion chambers. When we finaly assembled it and started it, it eventualy cloged the cat.
Also, I do not know if this is true or not, I head though if you run the engine at high idle will clean the cat out. this info may be slightly unrelated. but is some insight because it is part of the exhaust system. That, and I can't remember which member is rebuilding their engine or engines this week to the next anymore.
__________________
Iceman CAI, 55mm TB, P&P intake, Indy head w/1mm oversized Valves, Crane 14 cams, Pacesetter headder, OBX LSD, Unorthodox UDP, Solid bobble strut. solid front motor mount. prothane motor mounts. Battery in trunk, KYB-gr2 w/Eibach Sportline Springs, Eibach Sway Bars, Every bushing replaced with Prothane bushings.
Tags
57, 95, coolant, dodge, found, hemi, intake, mixing, neon, oil, ram, smoke, sprinter, start, sucked
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
