Thanks for the catch can install!. The one off to the side has the one way valve, I want to say it sees vacuum only, I will need to double check the arrow. It also came with washer that I was told are for tuning it.
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
ANother question. How to mount the filter on the turbo. After Installing it there is very little room between the inlet and the heat core lines. Also, what is the size of the outlet (charge side) of the turbo. Is it 2 inch? I need to order the coupler tonight, but the car is not here.
So a turbo will push boost thru the intake and up to PCV valve and pressurize the valve cover? That puts pressure on the oil and blows out of turbo seals? So is it wise to use the PCV system if you're going turbo? The PCM won't flake out if you don't use PCV right? Personally, I am sick of oil flooding my intake thru the PCV and if turbo makes it worse, then Frakk that stupid thing.
Couldn't you just run breathers and screw the frakkin PCV?
i thought that green/black neon looked familiar.....
when it was still for sale.....my mom was on her way to wisconsin and drove by it and stopped to take a pic to show me....
