Glasspack/Muffler from summitracing.com?
Old 04-29-2009, 11:29 AM
ldiablo233's Avatar
ldiablo233
ldiablo233 is offline
Default Glasspack/Muffler from summitracing.com?
They have cheap glasspacks/mufflers:
http://store.summitracing.com/partde...5&autoview=sku
But I'm not sure on the quality, and mainly sound. I'd like the glasspack so I can make a side exit exhaust, but ofcourse I don't want cops hearing me from miles away.
So anyone ever get a glasspack or muffler from summitracing? Opinions?
They also ship same day, which it tells you where its from and OH to NY is only a day or two or like 5 bucks shipping..
Old 04-29-2009, 11:41 AM
Altima_wb's Avatar
Altima_wb
Altima_wb is offline
lol glasspacks by themselves are not quiet by themselves no matter the brand so highly recommend staying away from them as far as the other muffler i'm not sure... but if you want side exit exhaust there are plenty of round style mufflers that will quiet more then a glasspack that will allow you to do your side exit...
Old 04-29-2009, 11:44 AM
ldiablo233's Avatar
ldiablo233
I was thinking of running a muffler down there but don't want to spend too much on one, plus most round style are fart cans. I've driven the neon without a muffler and I liked the sound, and not tooo loud so I might run the glasspack and leave the stock piping all the way back and see if I like that, but anyone got opinions on these products?
Old 04-29-2009, 12:08 PM
Altima_wb's Avatar
Altima_wb
the glasspack will be just like most... the muffler not sure but summit products are usually pretty good...
Old 04-29-2009, 03:16 PM
GLXRustang's Avatar
GLXRustang
GLXRustang is offline
I would go with the turbo muffler. Those louvers on the inside restrict exhaust flow greatly, whereas Summit says their mufflers outperformed a similar brand by 30 hp on a big block chevy (prolly dynomax). My bro put the turbo style on his 73 mach1 mustang and it sounded bad *** (no cats). Besides the fact that glass paks only get louder when fiberglass rots out over time. Ah to each their own tho
Old 04-29-2009, 11:36 PM
ldiablo233's Avatar
ldiablo233
Ok I'll just stick with the muffler for now, fits nice under the bumper and is less conspicuous. If I threw on the header and removed the cat, what would I do for the CEL?
Old 04-30-2009, 01:22 AM
Captansavaho's Avatar
Captansavaho
Captansavaho is offline
this is with 2.5" tubing with cat to a magnaflow resonator and magnaflow y pipe with a dual exit 3" tips..just headers and CAI at the time the video was takin
http://s8.photobucket.com/albums/a36...t=MOV01243.flv
Last edited by Captansavaho; 04-30-2009 at 01:22 AM. Reason: forgot to put in video
Old 04-30-2009, 09:07 AM
ldiablo233's Avatar
ldiablo233
When I take this muffler off I'm going to run it straight for a bit and see how I like it. I remember it having a nice growl to it when hitting high rpm's ans releasing, only reason I might not is the backfire.
Old 04-30-2009, 01:00 PM
GLXRustang's Avatar
GLXRustang
you need a 1/4 ohm resistor in place of the O2 sensor. There are three wires in all. Two wires should be black and one wire is white. (or vice-versa) That one different wire is the source, whearas the two black ones are for the heater element in the sensor. Wire the 1/4 ohm resistor between ground and the source wire and you're done.
I've got a header that I am going to install as well, so I will be doing the same thing with the cat since in my area no one gives a hoot about my car's toot.
I also want a better muffler, I want a hooker max flow, magnaflow or dynomax ultra flow (straight thru but with a perforated core, not louvered), but may just settle for the summit turbo. I'd like to keep my twin exit for that sleeper role tho...
Old 04-30-2009, 02:37 PM
ldiablo233's Avatar
ldiablo233
My o2 has 2 black,1 white, and 1 gray....
Quick Reply: Glasspack/Muffler from summitracing.com?
